Hall Sender leaking
Hi,
Has anyone had any experience of a hall sender leaking on the 4.2? Can't seem to find anything on the net or through a search about this. Thanks |
Is there anything in a Hall Sender to leak? If they become defective it's a case of chamging it. I belive its just a magnetic switch inside. I suppose it may be filled with a damping liquid.
How do you know it is leeking?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Thanks,
I had the car serviced, and one of the notes that came back was, "both cam cover seals and hall sender leaking" looked up and found info on the cam covers but not hall sender. If the hall sender was faulty would there be noticeable symptoms apart from it leaking? Is a hall sender replacement a pretty straight forward job? Thanks |
Ha Ha! You didn't mention Cam Cover Seals.
Its a regular on here. It isn't the Hall sender that is leaking but the seal around the cam position sender. A cam cover gasket kit will cure the problem and is a diy job. Here is how.
Ok nice one. I had found that guide but wasn't sure about the hall sender, but It now makes sense
