Old 19th January 2018, 10:47 PM
I've seen both handles, and the AV gear cause power drain. You need to divide and conquer this problem by eliminating one.
A cheap option might be to buy a couple more optical loops and loop out the nav, radio and amp.
Run the car. See if the power stabilises. If it does, whilst your door handles are faulty, they ain't the culprit. You can then reintroduce each one at at a time.
I have a car at the moment with a TV tuner that won't power down, and a radio module that was faulty causing the whole bus to break down every 30 to 60 secs.
If you've had water integers, there could easily be more than one culprit.
The other alternative is to disconnect all 4 door handles thus removing the short to ground errors and come from that angle instead..... I have another D3 at the mo that came with all the handles disconnected, presumably for that reason....
Old 6th February 2018, 08:29 PM
neeldub neeldub is offline
Any luck with the issue buddy?
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 6th February 2018, 08:33 PM
ChiefUno ChiefUno is offline
Not yet as I haven't had the money to buy all the handles yet...will wait a few months
2007 Audi S8 5,2V10 BSM
Old 6th February 2018, 10:02 PM
Booked mine today to have all four handles replaced, not a job I can do. Saving £1,200 off the price Audi quoted by using an independent
Old 9th February 2018, 05:13 PM
Wow is that really how much the dealer quoted? Parts alone would probably cost around £440 and for all 4 doors maybe half day labour if you know exactly how to do the job. Unscrewing the T15 screw to release the handle should be done very gently and tell the garage not to apply too much pressure while turning otherwise it will break the plastic tabs on the handle mount.
I'll post a picture later of what i mean.
Previously:
Currently:
Old 9th February 2018, 11:50 PM
Here are the pictures...
So this is the door handle mount
The plastic tabs are circled in red. They keep the screw and metal in place. once those snap off you'll need to install a new mount as it will be difficult to lock the handle in place.
Previously:
Currently:
