Exactly!
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill |
Seems to be all the rage with younger people though, taking selfies of themselves in front of the performers...….
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Ok then, the decision has been made.
Focal PS165F from the Performance Expert series in the front. Focal 165AS from the Performance Access series in the rear. JBL - S2 1224 12" in the parcel shelf. Out of production. New one: JBL Club WS-1200 Helix D ONE amplifier for the sub woofer.
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill Last edited by NightOwl; 29th April 2020 at 01:45 PM. |
I do But then I spend a lot of time in the wings backstage.
Quick update.
The subwoofer mentioned in the previous post is out of stock and out of production. So I've ordered another one: JBL Club WS-1200
I have a question. Will be adding an amp for the subwoofer and was wondering how to connect the power. Directly to the battery or will the battery management system be confused? Is it a way to connect so the battery management system will recognize and accept the extra current drawn by the amp? Tried to do some search, but its limited to find someone who actually has added an amp, and even more about how its done.
I'm not much of a person who documents every move with photos, so when I'm doing any projects, I hardly remember to take any photos before everything is done, and then it's mostly too late. This time i tried a bit harder to take some along the way, but this will not be a step-by-step guide as I think every person should add their own creativity to any project and not just copying.
I started with the rear doors and reusing the bracket from the BOSE speaker made it very easy, just to pry out the old speaker element and put the new one in the bracket. Even the screw holes fit. The tweeter is located high on the door, and the old one was just to pop out, but needed to use a Dremel a bit to make the hole slightly larger, then it was just to slide the new tweeter in and secure it with a bit of hot glue. Attached the crossover just over the woofer and connected all the cables. Yes, it was as easy as it sound here. Photo of the front and rear of the speaker in the bracket. And the tweeter without the cover. The front doors and dash was a bit more time consuming, although not difficult. Also there I was reusing the bracket from the BOSE speaker, but they are very different from those in the rear, so some creativity was needed to make it fit. First off, the mounting flanges on the BOSE speaker are located almost at the bottom of the speaker and with a slightly larger diameter than the standard 6,5", meaning the hole is too big. For this I made a ring out of waterproof plywood to get the correct hole and position for the new speaker. A couple of photos from the front door speaker front and rear. As we can see, I needed to cut away the "back cover" to make room for the magnet. After the photo was taken I glued on a piece of plastic to act like an umbrella to prevent water to fall directly on the magnet (make sure its not too deep for the available room in the door). Also the pieces for the woofer crossover was glued on the inside of the black plastic with hot glue. For the dash speaker grill, not sure the correct word, pops easily out after removing a couple of screws, and it's also easy to find the center of the tweeter position from the shape on the underside of the grill. Then its just to cut out the correct hole for the flush mounted tweeter and connect it all before assembling. A photo of the flush mounted tweeter. Everything worked at first try and during the test drive the sound was quite okey, but after some songs it was clear that the tweeter was a bit too loud. I tried to adjust the treble a few steps down in the head unit, but still didn't feel right. Back to the garage and pull out the crossover for the tweeters and flick the switch to -3dB and a new test drive. Now it felt so much better with nice balance between the woofer and tweeter. Me and my wife had a drive in the evening and she said the sound was much more 3-dimensional and she heard details in the music she hadn't heard in the car before, and I have to agree, the sound is so much stress-free and calm. It's like the speakers are ready for anything, you can throw complex music at them and they handle it as the most obvious thing. It was a massive upgrade from the std. speakers to the BOSE speakers, but I dare say it's almost the same step up from the BOSE to the Focal speakers. In fact it's a bit better than I expected as I didn't believe the std amplifier would deliver at this level. But this only makes me think it can even be better with a better amp. I have to mention the level of difficulty and it probably depend if you have std or BOSE sound system. Although I have never tried, I think it would be slightly more difficult coming from std sound system, as you would need to fabricate or buy rings to get the speaker in the right position and also find a solution for the rubber sealing towards the door panel. From this I would say the difficulty level would be 5 out of 10. Coming from BOSE speakers it's much easier, at least in the rear, and I would say the difficulty level to be 4 out of 10. In both cases you would need some tools and some materials, but it's more time consuming than difficult. One thing to mention coming from original BOSE system, is that the tweeter doesn't have a crossover (mentioned earlier in the thread), and that makes me think it could be a crossover under the dash where the cables split to the door and up to the dash. Other possibility is that the woofer and the tweeter has separated channels from the amp and the crossover is done there, but that is less likely. I used a LCH-meter to measure all cables from the woofer and tweeter in my non-BOSE wire harness and couldn't read anything than just the cables. But this is something I would take into consideration upgrading from a original BOSE system. In the next days I will dive into replacing the subwoofer and adding an amp for the sub. A question in the end, how much did the BOSE option cost ordering a new car? And how much for the B&O option?
Good result I'm trying to decide whether to go with Focal or JL in my current project.
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
#30
Thanks for the last comments above!
How to take out the parcel shelf seems to be a well kept secret. I took out the back seat and unscrewed everything I could see from above and in the trunk, even removed some of the interior pieces around the small triangular window, but still it was completely stuck. I've managed though to pry open a crack to take out the original tiny 8" subwoofer. Then it was quickly obvious that I couldn't reuse the original or BOSE bracket for my JBL 12", so I cut a double piece of plywood, in total 30mm, that I was able to bolt into the car and attach the JBL into. Connected the cables and turned on the music and huh?. Honestly, if I didn't know what I've done, I wouldn't hear any difference! What?! How could this tiny 8", that looked more like mid/high driver if it wasn't for the actual size, perform like the 12" JBL?! Hm, I noticed that both the std and BOSE subs was firing downwards, could it be phase problem? Switched the cables and listened again. Still no difference! Did it need to be broken in? Scratched some gray hairs while wondering how could it be this massive upgrade with the doors/dash speakers and not the subwoofer...................???????? I know it's not ideal to mount a subwoofer in "free air" like in a parcel shelf or even towards the backseats, but this was unexpected. Was this as good as it could be in so-called "free air" installation? Did I need a dedicated box to get it better? Questions buzzed around in my head. Half expecting that I needed to build a box for the sub, I decided to connect the amplifier mentioned earlier in the thread, that was planed to be used together with the sub first. Before I connected the amp, I noticed that everything was set to lowest from factory, so no loud sounds was expected when I turned on the music. Earlier I've set the sub level in the head unit to max to even get any decent response from the sub and now it was alive and kicking back there! Even at the sensitivity level in the amp set to minimum, the sub came to live as I've set the level in the head unit so high. Adjusted the level in the head unit back to normal and less than quarter of a turn up on the amp to compensate slightly, the output from the sub was more balanced with the rest. The I saw, as this is a dedicated subwoofer amp, that the LPF was set to minimum too (50 Hz)! Means it only let through frequencies lower than 50 Hz,and still it was kicking good! Adjusted the nob to about 80-90 Hz and lowered the level a bit more and now it blends quite good. Still lack a bit of definition on the bass as I can't hear the tones moving up and down from a bass guitar or other instruments with deeper tones. I'm pretty sure this would be much better with a dedicated box. I like surprises, because then I can learn something, and this was completely unexpected! The thing about adding an amp to the subwoofer was initially a test to see if the new amp triggered the surveillance police in the car and shut down the music and throwing fault codes. It did not trigger anything but the sub to come to life, so in the light of resent knowledge, I've ordered a new four channel amp for the door/dash speakers. For now I'm awaiting how things will sound after this amp is installed before deciding if I go for a dedicated box for the sub too. Maybe I'm in for another surprise? To be continued...
