#31
Ok so no P. I presume you have the PRND432 display on the cluster though?
Does it change to show the other gears as you move the stick with the ignition on but not running? |
#32
Gearbox help
That is correct all light up as I move the shifter and corispond to the position that shifter is in
#33
Gearbox help
#34
Ok so that could be a duff contact in the F125 or it could be that the shifter cable is improperly adjusted. Put it in P and loosen the two bolts on the cable bracket and allow the cable to find its own position then nip them back up and see if it helps. If not then you'll need VCDS to check what the TCU is reporting and verify what the switch contacts are showing.
#35
MJ, given the quick and dirty breakdown I did (from Ainars documents) in the other thread I'd put money on it being just an adjustment, resulting in an invalid code at the TCU so no display.
If one of the switches wasn't working it would almost certainly misread one or more of the other gear settings. Though as it's the "cam and switches" internals who knows, it could be a damaged section of plastic cam...…
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#36
OK do we have anybody on this forum near me with the vcds. I'm in North London area n99bx
#37
The test procedure was posted by Ainars in another thread. You can do most of this with a multimeter.
See: http://forum.a8parts.co.uk/attachmen...6&d=1597582836 Adjust it first as recommended by MJ obviously (it also states that in the procedure).
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 16th August 2020 at 04:52 PM. |
#38
Thanks shall get on that I will keep you all posted
#39
The procedure is somewhat disingenuous in that with the switch disconnected and ignition off you'll probably struggle to move the selector lever.
However, in reality, and certainly initially, you'll probably only need to test the various pins while it's in "P". In reality that will mean (if the F125 is OK): 1&2 connected. 1&3, 1&4, 1&5 all open circuit. 6&7 should also be connected when in P; without that (or a relay bypass like me! ) you can't start the car in P. But you say it does turn over in P so that's probably OK. It's important to note that the circuit to allow starting (6&7) is independent of the TCU input saying it's in Park (1&2). I expect it's the latter that drives the DIS. Though what else it does I personally have no idea......
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 16th August 2020 at 05:46 PM. |
#40
First start no exhaust 😂🤣
