Old 19th December 2020, 07:37 PM
89forever's Avatar
89forever 89forever is offline
Default Headlight wash
Bit of a noob question as learning the foibles of the D3....
Is it normal when operating the windscreen wash, the headlight washer system activates one side at a time???
I get the drivers side pop out and spray water, then once that’s done it’s spray it retracts and then the passenger side activates.
My previous Audi’s have always done both headlight washers at the same time....
Old 19th December 2020, 07:42 PM
Yes, but design. Only affects the output of one headlight at a time
Old 19th December 2020, 07:51 PM
89forever's Avatar
Well everyday is a school day.... how weird but at least it’s not broke
Old 20th December 2020, 07:00 AM
Makes perfect sense, only need half the power from pump and only affects light output from one light at the time.
Old 20th December 2020, 07:30 AM
The time delay and washer time duration can all be altered in the adaptation channels.
Matt
Old 20th December 2020, 04:26 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Hi Matt. Long time no see. Hope all is well with you and yours.
Do you know if you can alter the washer timing? As the spray from my headlight washers inevitably tends to find its way onto the windscreen, and need a manually activated pass or two from the wipers. (first world problem I know)
2007 Mini Cooper S R56
Old 20th December 2020, 06:21 PM
Hi John, all doing well mate.
I'll be honest and although it can be changed there will be some trial and error as I've not discovered what the T values are that can't be altered at they're fixed within the modules firmware.
Here's what the manual says...
HWS adaption:
Channel 6,HWS activation delay time / HWS pump activation times, value 0...255, range 0 - 2.55 sec
Channel 7,T3 / T12, value 0...255, range 0 - 2.55 sec
Channel 8,T4 / T13, value 0...255, range 0 - 2.55 sec
Channel 9,T7 / T16, value 0...255, range 0 - 2.55 sec
The times T5, T6, T10, T14 and T15 cannot be changed by way of adaption. The time T9 = T18 is calculated from T9 = (T2 + T6 + T8) - (T3+ T4 + T5 + T7)
If T9 < 0, then T8 = T8 - T9 and T9 = 0.
Otherwise the pump and nozzle run asynchronously!
HWS pop-up washer jet motor activation times:
Channel 10,T2 / T11, vaule 0...255, range 0 - 5.1 sec
Channel 11,T8 / T17, value 0...255, range 0 - 5.1 sec
Nice and easy so far
Login to module 4F, Security Access 12151, Do It, then change the values in adaption channels 6 - 11.
Just for reference here are some values (6-11)
100;40;100;70;75;100 from my A8
100;40;60;100;75;100 Factory Settings
Matt
Old 20th December 2020, 06:36 PM
Johnmed's Avatar
Very comprehensive reply there Matt. Thanks, and sorry for any unintended thread-hijack.
Old 20th December 2020, 07:08 PM
89forever's Avatar
No apology needed, it’s all good information
