Warning the same as the D2
Hence I misunderstood the initial question, which I read as if the car was supposed to stop accelerating at the set limit.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Yes, just a ding and red warning symbol at the top of the DIS. It disappears when the speedo goes above the set speed limit warning.
In my case: Set at 60mph.........warning at 67mph, approx. Set at 70mph.........warning at 77mph, approx. Speedometer v speed limit...............one of them is fibbing........maybe both! At least the warning mph's are consistent
2004 A8 D3 4E2 3.0ltr Petrol............baby A8 Last edited by Echo; 25th March 2021 at 06:07 PM. |
Ok, had a look at VCDS - 17 - Instruments.
Went to Coding - 07. This popped up over the coding: Clicked that off and here's the coding: Couldn't figure out how to get to the 'bits' and 'bytes' part. Had a look at this, starting at 1.28: https://www.youtube.com/watch?v=W4PHXY-K9G0&t=110s Seems my VCDS doesn't have any 'long coding helper' for the wheels
2004 A8 D3 4E2 3.0ltr Petrol............baby A8 |
The only place I know that you can input any wheel data is in Adaptation Channel 01, Nav module. Format is wheel circumference in MM. It's supposed to be used to correct the navigation. It may or may not be used by 0x17 for the speed limit gong. Worth a try changing the value.
Could you explain that in more detail please? In dummy language! Anyway, how come the bloke in the vid has the wheel stuff on his VCDS and I haven't? I thought all VCDS would be the same? This is my version: VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com
You'll be fine. Going from your previous posts you're doing well with VCDS.
Open 37-Navigation, then Adaptation, read channel 01, write down the current value just in case you may need it, then enter a new value (this will be you wheel circumference in mm), click Test then Save. The guy in the video can access that info only because the control module lets him. He was working on a newer car platform and it is dependent what is written in the firmware, so it's not a feature missing from your VCDS. The software / firmware in the D3 is generations old now.
But what will changing the wheel circumference in the Nav module actually do? I've put my new(17"), and old (20"), tyre details into this calculator: https://tiresize.com/comparison/ That was inches. This one is mm: https://tiresize.com/comparison/ So, I put in 2167.........yes/no? And thanks for explaining the Youtube VCDS stuff EDIT: Sorry, can't get the links to work properly. Just click on the inches and mm to compare.
2004 A8 D3 4E2 3.0ltr Petrol............baby A8 Last edited by Echo; 26th March 2021 at 04:30 PM. |
Yes. Although you could experiment with obviously small and larger values.
