Fault code after replacing oil filter gasket
Evening all, finally got around to tackling this and it wasn't too bad. Intake manifold off, cleaned everything, replaced gaskets and everything put back together. On start up, it seemed ok (no warning lights) so turned it back off whilst I cleaned some other bits. On final start up, MIL was on and VCDS gave the following code:
001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1) P0660 - 004 - Elect. Malfunction Is Bank 1 on the right hand side as you stand in front of the car? I have checked all connectors and it's all plugged in. When the manifold was removed, I cleaned it carefully and didn't remove the motors or arms so as not to disturb the position. The flaps were removed around 3 years ago and never had an issue. Does this seem like a motor issue or an electrical one?
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder |
Bank 1 is on the right side as you sit in car
As a matter of interest was there much carbon in the valve ports ,i'm guessing you got the cleaned when you deleted the flaps ?
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
Thank you
Am I right in thinking you shouldn't be able to move the motor arms by hand?
