Aircon - 00792 - A/C Pressure Switch (F129)
Hi There,
Was just checking the codes and this came up. Its only the start of the warm weather and I had been noticing the aircon not working well. Ross tech has http://wiki.ross-tech.com/wiki/index.php/00792 Last year I regassed the system http://forum.a8parts.co.uk/showthrea...ghlight=aircon The preasure check it by holding a vacuum and it did that no problems. No one has really been near the system since and it was working fine last year. A leak isn't imposible, but i'd guess unlikely. So i'm guessing a switch. Any idea on where etc. or other ideas Ta, A rather warm Lee |
The only way to check the switch is to make sure the system is up to pressure then measure the resistance on the switch. The switch allows the compressor clutch to engage if the system is at the right pressure and the compressor is required to run. If the switch is not allowing the magnetic clutch to operate, (you can test the operation of the clutch in the output test in VagCom in the HVAC section) it's either because there is no pressure of the switch is duff.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Any idea how to opperate the clutch in vagcom. I have an old dodgy ebay one, but it seems to work quite well !
The error is Intermitent and Short to B+ if that helps ??? |
I'll post a screen shot tomorrow with a wee how to.
Hi Conan,
Did you manage to get a screen shot ??? Ta, Lee |
oooops sorry forgot. I'll go out and do it now.
Here we go. Open VCDS to the HVAC page and select button 03 (bottom of column 3). You'll see this:
Hit start and cycle through the tests and you will see this: Once all the tests are complete check the faults section to see if any registered. If there is a clutch fault then it is possible you have a faulty clutch. The other 2 options are low pressure and pressure switch.
