Motormouth Everything, and anything else motoring related that just doesnt belong anywhere else |
View Poll Results: How do you use your transmission | |||
Tip full time and actively engine brake. | 3 | 10.34% | |
Tip for gear changes but brakes for stopping. | 1 | 3.45% | |
Stick it in drive and leave it there. | 6 | 20.69% | |
Mixture of Tip and D. Brakes for brakeing | 18 | 62.07% | |
Is there anything except Sport! | 1 | 3.45% | |
Voters: 29. You may not vote on this poll |
Driving Styles........
One of the hottest topics on here is the transmission's foibles. I have now had 4 of ZFs finest on 3 8s. None have failed, all have performed flawlessly. Except the one I kicked back onto the TC and broke the oil pump!
We talk about servicing as the only variable in the transmissions life, but I have got to thinking about driving styles. So I thought I would run a little poll to see how we all use our transmissions. I always drive in Tip; and I use engine breaking at all times to reduce brake wear, with the exception of spirited track and private B roads runs. I will change down through the gears long before I would need to brake for junctions or lights and see it as a point of honor to not put my brakes on until I'm in 1st. This means my transmission valve body is getting a good workout all the time and I wonder if that's why I have had no problems. Thoughts?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Mix of D and tip for me with brakes for braking - must admit it is VERY rare for me to use anything other than D unless I'm on a country road and will then use S to keep the engine on the boil.
Tip is basically for playing silly buggers with slower cars when I want to make a point like blowing the Cooper S into the weeds that was climbing all over the back of the car through a 30 so stuck it in tip and 2nd gear to show him how a proper car accelerates Not sure any of this makes a difference to gearbox life unless you spend all your time cooking the gearbox oil with left foot braking, aggressive launches etc etc Big difference with mine after the gearbox oil was changed was how sweet the box felt and smoother changing between D and R
Mostly tip as I can switch in higher gear sooner and keep in higher gear for longer making engine work at lower revs this has improved mpg by 1-2 mpg on short local runs. It also allows to preselect lower gear saving time on downshifts when flooring. I do use engine braking selecting lower gears but combined with brakes in all gears not like Mike only using brakes in 1st gear.
You have missed my driving style out ...........lead stiletto flattened to the floor at all times
Tend to leave in D to be honest.
Every now and then I will use the tip but not often. So far (touch wood) no issues with the 'box
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice) (Engine poorly so sold on to be brought back by someone who has the time) |
The RS6 is currently my daily driver, and when I'm going to work I just 'pootle' along, but I am constantly putting it in a higher gear using tip as it can comfortably cruise in 4th when the computer is deciding that it should be in third, ideally I would like it in fifth but the TCU won't allow it. I use sport mode in country lanes for when you slow down for a corner, the car is holding the revs just right for when you put your foot down again. But most of the time it is in D with me giving it some assistance now and again, very occasionally I'll use tip to go down a gear when overtaking someone, but there is so much torque from the twin turbos I hardly ever need too, and kick down works fine too.
Strangely I drive the 8 mostly in D then use tiptronic when on a fun a or b road or when overtaking, whereas in the 7 I use sport mode a lot of the time and drive mode in London traffic etc, and more rarely the paddles, but you can use the paddles at any time to over- ride either S or D mode and then it reverts back to that particular mode when it decides you've stopped using the paddles regularly
Boxster does this too, much better IMO, think the D3 does this as well
All Audis with the [S]ports mode on the box will let you use the paddles without first going into tip mode - So late D2's, all D3's, RS6's etc
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
I tend to leave the stick in D. On the odd occasion, I'll use S to overtake a long line of automobile, or with the stick in D, use the Tip paddles to drop a cog or two.
