D3 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Centre caps
The Audi centre caps seem to suffer a lot of corrosion around the outer ring.
So I decided to have a look underneath to see what could be done about it. Sadly the only way to remove the ring means destroying it as it is crimped on the full circumference of the cap. That ruled out any chance of refurbishing. All is not lost though as the area underneath the ring is painted the same as the rest of the cap face and with a bit of spit and polish looks not too bad. Now I can have a choice of plain centre cap rims or polished...
. Nite Blue 3.0L SE Quattro |
centre caps
I tried taking one of these apart and failed miserably....wanted to respray the the four rings and the outer bit...but I couldnt work it witout breaking it....if anyone can shed light on this would be great...
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
The 4 rings are made from plastic and are held in place with 2 pins and 4 tabs, the tabs have one way lugs on them and the only way to remove them would be to break the tabs, they would then have to be glued back into place.
I found one of those exact caps by the roadside the other week walking home from t'pub.
Picked it up thinking someone here might want it for a spare. But when I cleaned it, as above the outer shiny ring was badly corroded and the Audi rings a bit tatty. I too looked at it carefully to see if it could be dismantled and "sorted" but found the same challenges and binned it. I was surprised how many carefully designed and made components were in it though, I was expecting a much simpler object than I found.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Decided to have a go at removing one of the outer rings without mangling it.
There are 3 tabs which require straightening Then you need to un-crimp the outer edge of the rim and with some gentle persuasion the ring will come away from the backing The amount of crud inside is a poor design, salt water getting into the back does nothing else other than assist the corrosion So I decided to try and clean a small section of the ring I started with 400 grade wet & dry then 2000 grade If you zoom into the image you can see that even after removing the lacquer (light silver/white sections in the image) and etching (light grey sections in the image) and rubbing away at the bare aluminium (dark sections in the image) there is still lots of pitting which would be difficult to remove. My conclusion, either remove the rim as per picture 2 on the first post or buy new caps If anyone has a spare cap which is corroded and they don't require it I will happily take it off your hands as I only have 3 Checking the 4 rings logo it looks like it is wedged in with tapered pins and I suspect with a little force should be removable
. Nite Blue 3.0L SE Quattro Last edited by 47p2; 18th April 2012 at 03:52 PM. |
Good news Ranj, the centre rings do press out Using a small blunt instrument press the tab using a steady even pressure until it is level with the main body, Do this with all 4 tabs, no need to bother with the round pin as it is for locating only and just slides through. Then turn over and ease the rings out from the main body Get the rattle can out and paint whatever colour you want
