D3 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
#31
Some of them were there before the ECU problem but I was not confident enough to experiment with VCDS.
When I did a scan at the weekend there were a lot of errors that I put down to low voltage etc. so I tried to clear them. The auto clear did not change anything so from your earlier post I tried one controler at a time and most of them cleared. I was then left with the four. This afternoon I did another autoscan and that is the scan I posted last. I'll concentrate on your last comments and try to work through it. After that I will try Ross Tech support as per your suggestion.
