Old 16th November 2015, 04:28 PM
I just checked mine when I went to the shop, if the HVAC is off and you press the setup button or AC in your case it should swirch on the HVAC system but bring up the menu in the MMI I guess your not getting the menu?
Old 16th November 2015, 05:48 PM
Conquistador's Avatar
Tried that and it just does AC. Nope, can't get into that HVAC menu at all
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 16th November 2015, 05:49 PM
Funny, but I have none of those buttons on my D2 ...... Oh, sorry, thought this was a D2 thread
Old 16th November 2015, 05:54 PM
Oops!! Need to get used to posting in the D3 section again
If an admin can move then please do.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 16th November 2015, 06:13 PM
Perhaps a chat with the previous owners will reveal what's gone on. For what its worth, looks to me like you need to try the unit with a setup button from someone who can make the temporary donation. Is this an easy swap?
Old 16th November 2015, 06:57 PM
Looks pretty straightforward to get at....
File Type: pdf D3 J255 climatronic control module removal.pdf (80.4 KB, 259 views)
Seem to remember that there is component protection on the HVAC controls?
Old 16th November 2015, 10:33 PM
Moved
Old 17th November 2015, 01:21 PM
Place near me does component protection for a lot less than main dealers charge. From memory it's about £20 if you don't need anything else doing in terms of fiddling. I suspect if you actually had the part fitted by them that charge wouldn't apply either.
Old 17th November 2015, 01:27 PM
That's cheap. Who are they?
Matt
