Old 15th April 2016, 03:46 PM
That document doesn't have any D3 pressures, only D4 for some reason. It has everything else for both.
Old 15th April 2016, 04:20 PM
Rick Rick is offline
Hows that then? Its 2003-2010 models. Didnt think D4 was in that year bracket?
Old 15th April 2016, 08:49 PM
The document says on the page headers it covers A8 4E 2003>>>> and A8 4H 2010>>>>
and each section has information for each.
The pressures section only mentions 4H and has many missing standard 4E sizes so I presume the section pertains only to 4H even if some tyre sizes may be the same and even pressures. These are screenshots of document 43 from the PDF section and it is missing from the PDF.
Old 15th April 2016, 09:01 PM
Lee S Lee S is offline
And nowhere is the 275/35/20 either so not every tyre you could want...
My D3 4.2 TDI on the above tyres should be (according to filler cap) :-
normal load is rear 33psi or 2.3 bar and front 36psi or 2.5 bar
full load is rear 41psi or 2.8 bar and front is 44psi or 3.0 bar.
Lee
2017 Nissan Leaf Tekna
Old 15th April 2016, 09:04 PM
I run 40 psi all round on the 20" FE wheels with 275 35 20's also
Old 15th April 2016, 09:24 PM
Interesting, I run 36 all round, which is the recommended D2 pressure, though that's 255/35R20. (46 all round when fully loaded.)
Old 15th April 2016, 10:31 PM
That's on my D3 - the D2 Kahn wheels are on 40 as well due to low side walls on 25 and 30 profile tyres - don't forget I am often carrying passengers and luggage with the D3's!
Old 16th April 2016, 06:37 AM
But, as the diagram clearly indicates, 36 psi is for a load of 3 stick people and one brick. And 46 psi should only be used when carrying 5 stick people and 3 bricks.
Usually I go for somewhere in the middle (about 40 psi), to save frequently adjusting the pressure, even though I rarely carry any bricks ... or stick people.
Old 16th April 2016, 01:58 PM
Haha. Brilliant.
Old 16th April 2016, 05:22 PM
Of course, that's why I just said "interesting" and pointed out it my figures are for a D2; I do know this is a D3 thread.
