Old 24th April 2016, 07:22 AM
if your going to do this, it might be benificial to have a look at the kufatec model, i picked this up on a thread on another site. The kufatec has DAB plus (and other stuff)which not only picks up more channels and is the more upkeeping with the latest tech it may well be better quality sound. this particular guy was in one of the nordic countries which doesnt have that many DAB channels and all new ones are on DAB plus.
if your going to do it you may as well have the latest
https://www.kufatec.co.uk/shop/en/fi...-mmi-3g-mmi-3g
you can get a 2nd hand audi oem for around £100 on ebay though if your lucky
Old 24th April 2016, 09:40 AM
Burnzybubbles's Avatar
My DAB is faultless, I use it everywhere and only sometimes does it drop out of signal if in the middle of nowhere on the motorway, but pretty sure I can go from Birmingham to London without a single drop of reception.
I can't remember if DAB works properly on the TV ports on the antenna, I know I was using mine for a bit with the wrong aerial port but I'm pretty sure using the correct aerial the signal was much improved
Old 24th April 2016, 08:13 PM
My DAB reception was very spotty but since I changed the aerial unit (Thanks to our sponsors) improved an awful lot. Now it used even more than the AMI, even by the grandkids.
Old 25th April 2016, 06:20 AM
Artermis Artermis is offline
Cheers guys, I have an antenna unit and DAB module sat on my desk - just waiting for the correct fakra antenna cable to arrive before I do the job.
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
Old 25th April 2016, 06:22 AM
Went shopping on a Polish site - got the DAB module and antenna array board for £75 delivered :-)
Old 25th April 2016, 06:30 AM
that is good value
Old 26th April 2016, 10:06 PM
irelandbuyer irelandbuyer is offline
i did mine - changed the analogue to the hybrid unit, was lucky enough to get the unit half price from a8parts at one of the open days.
still it was something i thought i had to have, since then i must have used it a couple of dozen times, the kids watch their movies all the time, but rarely the tv, so in theory i could have just stayed with the analogue.
like so many of the retrofits the must have becomes a rarely used toy
HI there, may I ask a silly question, how do your kids watch their movies? (Is there a DVD slot i've missed somewhere?) Or, are you connecting another device into your system? (please, no slagging...i'm only getting to grips with all this : )
Old 27th April 2016, 11:11 AM
we dont do slagging here
The hybrid unit was put in with all three cables AV1, AV2, and AVOUT
i connected a DVD/SC/USB player in the boot with a remote eye
Connected the output of the dvd to AV1
connected the OUT of TV to the In of DVD
This means that the rear headrests can watch DVD sdcard etc or The TV
and most importantly when they are little, everything can be controlled from the front seat with a remote.
