Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 4th October 2017, 08:39 PM
Oh OK that's what you call it.
Oh right, yes of course. With free entry too, you could just slip in there Mark especially if it's wet, doesn't matter how long it takes you
Thanks David. Might give the museum a try.
I do like a bit of culture and edumacation
Old 9th October 2017, 10:32 AM
Well Mackies did a good job as usual. Box running perfectly and serviced for another year.
The museum was interesting (though the Salvador Dali painting is no longer there). Thanks for the recomendation David
Name:	2017-10-06 16.20.51.jpg
We also had a long walk around the city. Lyn wanted to visit some candle factory south of the Clyde, so we found ourselves walking through a rough looking part of Govan too, which was .... interesting. I half expected to see Rab C. Nesbitt walk past us.
Troon was nice. We stayed in a seafront apartment here:
Name:	2017-10-07 10.10.24.jpg
ID:	17210 Click image for larger version
Name:	2017-10-05 16.27.09.jpg
Old 9th October 2017, 10:34 AM
I think you've started a trend now, all D2 servicing "events" are turned into a mini-break.
I wonder if MJ will open a B&B?
Old 9th October 2017, 10:38 AM
Now that would be a great idea!!
Old 9th October 2017, 11:25 AM
Hey! don't make me swear ffs, I'm doing the accommodation side of things here. Link to previous thread, where DEZZY'S sorting the accomadation
Old 9th October 2017, 01:10 PM
Perfect.
Does it come with a sea view?
Old 9th October 2017, 02:37 PM
Perfect.
Classic
It can come with a seagull? 4' Cornish one that'll pinch your chips
Old 12th October 2021, 10:25 PM
sarg sarg is offline
The S8 I have in at the moment came in to the workshop with the brakes almost on fire. Turns out the inner pads were jammed solid in the calipers and only the outer pad was moving, caused by rust on the edge of the pad backing plate, plus dirt and brake dust building up on the caliper. The calipers on this one were reconditioned a couple of years ago, but the Brembos are a flawed design in that regard as the clearances are so tight. I pull the pads and clean everything up every oil change which stops them getting stuck
(I also pull and re-grease the front strut pinch bolt every oil change too )
MJ, could this be causing the brake smell and heat I described?
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 13th October 2021, 07:15 AM
That was top suspect, but they aren't binding - I checked that.
