D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc |
VCDS coding needed from a fully loaded D4.
Hey guys, i'm after a VCDS coding from a facelifted 4H D4 (2014 and above) for a vehicle which has the following options fitted to it as i want to check the coding to enable those features on my D4.
- Adaptive cruise control - Active Lane Assist - Traffic Sign Recognition - Side Assist If anyone can kindly help out..many thanks
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey |
Don’t those options need the appropriate hardware, surely not just a case of coding?
I think Ray may be your man there for that coding, I'm sure his new D4 A8L FL has most of that. Wouldnt the coding be evident from the options on each section though?
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
So i just want to try the coding from a factory enabled car with all those options just so i can check whether i missed anything while attempting to code myself with VCDS. Unfortunately i cannot find anything on Elsawin, wiring diagrams or technical instructions, in regards to the features i am trying to enable, hence i have concluded it's more of a software feature than hardware. Thanks
Will this help?
I followed the following coding guide from an A6 C7 which successfully enabled Active lane Assist. https://forums.ross-tech.com/showthr...-Retrofit-DONE Now the A6 and A8 share the same hardware in regards to the Electronmechanical steering, Onboard camera and image processing unit. Having enabled the coding on my vehicle, the Active lane assist did work, however there were many errors on the 5F control unit and instrument cluster about missing messages and the Active Lane Icon on the dashboard would constantly flash indicating an error somewhere. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1 Part No SW: 4H0 920 950 R HW: 4H0 920 950 R Component: TDieGBACC---- H53 0707 Revision: 37081202 Serial number: 658171014592036 Coding: 338F08001F412600010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004050 ROD: EV_RBD4K.rod VCID: 377AA14F8E3774F22C-8062 Analog_clock: Subsystem 1 - Part No SW: 4H0 919 204 Q HW: 4H0 919 204 Q Component: Analoguhr D4 H05 0225 Serial number: 2141112000391 1 Fault Found: 16776980 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 8 Mileage: 63474 km Date: 2019.03.20 Time: 19:14:49 -------------------------------------------------------------------------------
Many thanks.. i shall have a look
What year is this vehicle built please?
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey Last edited by neeldub; 26th July 2019 at 10:27 AM. |
Just off for a drive to Tywyn for the Tall-y-Llyn railway.
Many thanks for the coding. Can you confirm if the coding you sent are the factory ones or have you conducted some VCDS tweaks? Does the steering wheel actually vibrate when you go across the white lines while active lane assist is on? Thank you
A friendly bloke with deep knowledge of 8's tweaked a few things on the day of purchase. Personally, I have no idea of the details.
Everything was updated at that time. Everybody says that it vibrates, but my opinion is that it fights you to prevent you doing what it thinks is wrong.
