Old 21st February 2021, 04:20 PM
A8twopoint8 A8twopoint8 is offline
Ahh... Andys old car.... Thatd been for sale for a little while.
Changed hands a few times just recently.
Good spec car, nice to see it arrive back on the forum
Yeh its changed owners twice in the last year or so, just weighing up whether to change the timing belt or not?
Audi seem to suggest every 105'000 miles, according to the service history the belt has only done around 40'000 miles since the last change but that was 11 years ago so im thinking it could do with changing....
Old 21st February 2021, 04:29 PM
Change it The belt doesn't tend to fail, but the hydraulic tensioner does. Use the INA kit - its oem parts without the rings, for £250. Also worth doing the water pump and thermostat (genuine for £120 ish).
If you're DIY-ing it, I have the locking tools for hire
I think it had problems with the head gasket from memory, so I guess the heads must have been off. If they were off, you'd hope the guy fitted a new belt at the same time.
i'd definitely pop the covers and take a look at the condition of the belt before assuming it needs doing....
7 years is the general max recommendation for the D2 timing belt.
Old 21st February 2021, 04:33 PM
Definitely won't be doing it myself My mechanical skills are limited to uncomplicated bulb changing!
Thanks for the advice though i think I will get it changed to be on the safe side.
Old 21st February 2021, 04:35 PM
Thats interesting, do you know roughly what happened with it and when?
Hopefully its all OK now
Seems to run OK but Ive not really been out in yet
Ive had a quote from a local VW/Audi specialist of £625 for the timing belt kit and waterpump supplied and fitted.
You are going to need a change of username now
That's pretty cheap for £400 of parts and a day's work.
Old 21st February 2021, 04:37 PM
I know! Maybe Ill just debadge the car instead
Old 21st February 2021, 06:17 PM
Heres a couple of older posts about it...
http://forum.a8parts.co.uk/showthread.php?t=8747
http://forum.a8parts.co.uk/showthread.php?t=15756
Old 21st February 2021, 06:47 PM
Thanks for that, note to find some info out about the car
Tags
for sale, wanted
