Old 23rd October 2021, 06:57 PM
Ronin Ronin is offline
I've got my subframes and fuel tank brackets ready for powder coating, I'll let you know how much it was so maybe we can compare to other parts of the country
ID:	27376   Click image for larger version
Old 25th October 2021, 11:37 AM
This one on ebay worth a shot?
https://www.ebay.co.uk/itm/Audi-A8-4...-127635-2958-0
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 27th October 2021, 12:59 PM
It's stupidly expensive, I've paid £50 each for front and rear. If I can get mine done I can send you the one off my car and I'll keep the one off yours? I'm sure something can be worked out
Old 27th October 2021, 08:15 PM
Sounds like a plan going forward
I am in South Wales every 3 weeks so can execute swap / pickup when suits.
Paul
Gosport UK
Old 28th October 2021, 06:00 AM
That's cool if you get round to it sooner than me I'll just give it to you and once you have your old one back you can give it to me. I live 2mins off junction 32 of the m4
Old 1st November 2021, 07:20 AM
rear control arm bushes have appeared on autodoc at an affordable prices:
https://www.autodoc.co.uk/car-parts/oem/4d0505171l
Old 1st November 2021, 07:46 AM
Interesting - thats the A6 bush which I have been using. Someone else has obviously also figured out it is compatible with the D2 and updated the listing
Old 21st November 2021, 12:06 PM
roberto's Avatar
roberto roberto is offline
this is the type of corrosion i have been seeing on many Audi,s
mainly the scottish ones or been near the coast
we have shot blasted 2 now off audi A2,s that we have been refurbing
thank god the D3 has an alluminum one
Old 30th November 2021, 12:53 PM
Stromaluski's Avatar
I've been slowly replacing the rear subframe in my S8 due to rust issues on the original subframe. One thing I have figured out is that it was designed to be assembled outside the car and then installed into the car as a unit.
I put the bare subframe in and then started putting parts on it. There's quite a few bolts that you simply can't get to with a torque wrench once the subframe is in the car.
Just in case that helps anybody.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 30th November 2021, 02:52 PM
Yeah the upper control arms are not fun to access with it in the car. I've dropped a side at a time to deal with those in the past, but much easier to assemble it on the ground and then lift the whole thing in to place.
