Old 20th January 2011, 04:45 PM
frankow's Avatar
frankow frankow is offline
Default LED Side Lights
As per a much earlier post I converted the sidelights to the twin LED style and I must say it brings the car upto date, I love the look!
Sounds stupid but it really does make a difference.
Old 20th January 2011, 07:09 PM
Night Train's Avatar
They look very nice,
I fitted the same (15) LED lights as our illustrious librarian has, they really make a huge difference on the pre facelift model, both aesthetically and light output wise. A huge improvement over the OEM, and reasonably subtle too, & as Mike aka Conan also pointed out, no issues with the DIS regarding bulb failure.
Other vehicles
Oh Yes....... The '98 PF S8!
Last edited by Night Train; 20th January 2011 at 07:11 PM. Reason: additional info
Old 20th January 2011, 07:53 PM
Perfect, I did this on my old car. But there are some cheap ones knocking around. Do you have a link to yours, and have you thought about doing the numberplate bulbs?
Old 20th January 2011, 08:02 PM
Mine are traditional projector style headlights with "maypole" style LEDs which look almost headlight-like at times
these pics are just with sidelights on lol
ID:	1579   Click image for larger version
ID:	1580   Click image for larger version
ID:	1581   Click image for larger version
ID:	1582   Click image for larger version
Old 20th January 2011, 10:08 PM
frankow's Avatar
Wow, they look great....so bright!!!
Where can these be purchased?
Old 21st January 2011, 11:33 AM
You would want either These or These depending on your fitment
You can tell what bulb type you need for your model Here generally the bulbs changed from a bayonet to a push in fitting from '02 onwards
Old 21st January 2011, 12:25 PM
But 'generally' is the operative word. My 02 S8 and 52 A8 (both with Xenons) both have bayonet fitting side light bulbs (with LEDs!)
Old 21st January 2011, 01:37 PM
Mr K Mr K is offline
Mine are bayonet fitting on an 02 s8 with bixenons. Found that out after i bought the wrong ones.
I have these fitted too, so much better looking and brighter.
Old 21st January 2011, 05:17 PM
mine are push fit 501's on 1997 so it must be other way round
Old 21st January 2011, 09:25 PM
I opened first link and the size is 31mm long x 22mm wide. Don't order this, as they are too big. There was a mistake somewhere along the way. Can anyone recommend correct bulb for FL 2002 car please?
