D3 - Common Faults Quick links to all known common faults and their solutions |
injector 5 fault or lean fault?
Check the fuel pressure.
Maybe it is time to take it back to whoever did mapping and ask what they think. I am sure they can switch back to original map and then back to economical again to confirm or rule out mapping issue for free or a small fee and modify map if required. They might even point out the fault while doing it. |
have you checked fuel pressure?
No how do i get that checked?
Depends on year and engine code, here is pdf with example for BFM and BFL engines
right ive put original map back on and the light stayed off for 400miles and its come on again! any suggestions before i take it to audi to fix and rip me off???
Which fuel have you ran for the 400 miles?
#30
i always run it on shell v power
