Strange constant fan/motor sound
Not sure if this is engine bay or inside (heater/aircon) but you can hear it inside the car. It's annoying, worrying and perplexing.
Bonnet open and it appears to be central just in front of the windscreen under the big air intake. It's a steady noise, but only there when the engine is running, does NOT vary in speed at all and nothing I do changes it, other than turning the engine off. Turning the ventilation off makes no difference (it stays there) and it's not on if you turn the key, until the engine has actually started. I'm running the ventilation in "econ" mode (no aircon) anyway until I get round to clearing the "orange" drains; at first I thought that might be related, but changing anything & everything on the ventilation makes no difference at all. It sounds like a fan with a "slightly dodgy" bearing or with some dirt caught in it. Whether it started today or just got a bit louder I can't really say. At speeds above about 40/50mph it's not noticeable (depending on the road surface noise). Any thoughts anyone? |
Aux hot water pump. It is used for the resting heater and fails with remarkable success. It will create an awful bearing-like scratching sound like your engine just ate a spark plug.
It lives under the passenger side of the air intake. I think I've documented it on here before. It will spin up a second or so after putting the ignition on, and stays on. The real test is to run the resting heater, which will also put it on. That should be pretty conclusive. Not too expensive, couple of hours to change as its easiest done from the passenger side of the bulkhead with the glovebox etc removed. A8parts are well aware of the fault and should have a replacement handy
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
So what are the implications of not doing it immediately? Or can it be bypassed or turned off - I've NEVER used the resting heater until just now. It's not a job I'd do myself either; is it something I could get a competent motor mechanic to do, or would I need a Audi specialist? |
Its just the bearings on the motor. We've known people just unplug the motor to stop the noise (quite easy to reach the cables from the engine bay side) and the only thing that seems affected is the resting heater.... The pump runs continously, but the heating doesnt seem harmed by not having it running.
I guess either specialist would do. The motor is screwed on using two screws from memory, but these cant be accessed from the engine bay as the blower assembly is in the way. By removing the glovebox, and then pulling back the carpet and acoustic foam insulation, you reveal the large square plastic cover which is held on by 4 hex nuts. Remove these nuts, remove that cover, and then my memory goes a little hazy, but remove what ever is under there to get reasonable access to the pump. undo the screws, remove it, stick another one in.
Thanks for the info on access; I may well see how much a replacement is and get one in (from A8parts obviously) to add to the collection of "bits" that need fitting and minor things that need fettling "when the spring comes". |
I'd say "extremely" easy.
Bonnet up this morning, turned on "rest" and it was immediately obvious where all the plumbing etc was, just to the nearside of the air intake. There are 2 connectors right there, a "yellowish" one to the front and a "purplish" one by the windscreen, both just held by clips. No tools needed, took maybe 30 seconds. Disconnecting the purple one stopped the pump. I'll go back when it's a bit warmer (let's say above freezing) and tape up the exposed contacts. Then I'll give it a day or so and see if any codes show up on Vagcom/VCDS. (note to self, sort out my paid-for Vagcom and get it properly transferred to VCDS on my Windows 7 laptop) A8parts currently seem to have the full unit of pump, plumbing, valves etc. on sale but that's a bit pricey; will have to see if they just have the pump (assuming it's feasible to just swap that). Might even pop in to Amersham Audi and see what price they would charge for a new one. Last edited by HPsauce; 30th January 2012 at 08:05 AM. |
Give a8parts a call direct, there is a limit as to what they can can list on Ebay, but almost anything is possible if you have a chat with Carl
Will do, I've sent emails in the past and had very helpful responses.
Now I know what it is it's gone onto my (rather too long) "to do" list so will have to wait a while. Thanks very much for your help; where else could you get a car problem diagnosed (free!) on a Sunday evening after 9pm? |
It looks like the part number is 4D0 959 617 C. Dealer price £859.72 inc VAT, ouch...
Ouch indeed.
That is the whole unit with valves and plumbing though. There's a used one on eBay for £99 as it happens, quite near me. |
