Clutch questions
Not really the most technical questions but . . . . .
I have a 2003 4.2, i've never had an automatic before so i dont know the answer but can you tell if the clutch is going like you can on a manual ? Does the clutch even work the same way ?, is it ok to sit in traffic with stick in "D" foot on the brake ? Or should you move to "P" everytime ? |
I think it depends on how long you're likely to be waiting for. If its a large junction where the wait is longer then I just knock mine into neutral and put the handbrake on, if you put it into park then it alarms the car behind when your reversing lights flash on as you go through reverse to get there!
If it's just a short while then I keep my foot on the brake for a few secs and then pull off as normal If the clutches are going in the auto box then it will slip in a gear (or more) and the gearbox will go into limp mode and all the gear indicator lights on the dash binnacle will turn red.
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
I guess i'm still a bit nervy of my new purchase and the speed is so effortless that its hard to keep an eye on both |
I honestly can't recall the last time I did, other than when deliberately "playing" on an empty road.
Remember it will change down gears anyway with extra power in some situations. Plus it's an auto box with torque converter and I think only top gear has "lock-up" so revs can vary quite a bit. Not sure what kickdown you will have, some FL versions have an actual switch under the throttle pedal.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Definately dont have a switch under the pedal, but the particular stretch of road forms part of an across the hills typical single lane national limit road, you turn into off a t junction and its progressively up hill for about a mile, nothing major but it only sticks in mind because its does cause the revs to shift and gears to change more than most.
I guess in a manual if it changed that much i'd "know" much clutch is gone which prompted me questions being a newbie to autos |
If in doubt try the same road using manual shifts and observe what happens.
Autos can do odd things and, as was pointed out to me here recently, can sometimes be "fooled" into doing very odd things.
I was always told it was best to leave the box in D unless stationary for a while. Theory being the oil in the box is only circulating while drive
is engaged so it keeps the box cooled. Moving between d and r or n on a really frequent basis (eg at every junction) will place more stress on the box than leaving it alone
No need to put in P or N on junctions even if you have to wait for a while. Leaving in D will not damage gearbox, only downside is a bit higher fuel consumption as engine have to use a bit more power to turn it self and gearbox rather then just itself. But switching in neutral will not harm either as oil pump in gearbox is working and circulating oil regardless of which position lever is.
Clutches only wear out if they are slipping because of other faults like low oil pressure which can be caused by leaking seals, low oil level, clogged filter ect. The slippage you experience is most likely the one in torque converter which is normal but it's hard to say without actually seeing it in person.
Ok, slightly embarrassing but I do have a switch for the overdrive, not sure how I missed it but guess I thought it was just a pedal stop
Any downsides to the switch ? So if it's the torque converter im assuming the effects of the slipping will be less in sports mode, ive done a little testing and from what i can tell it definitely seems to be the case. |
