D3 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Are these figures correct for d3
SIZE - 19x9.5
PCD - 5x112 OFFSET - 45 CENTRE BORE - 73.1 |
Centre bore should be 57.1mm for D2 and D3 and 66.1mm for D4.
PCD is 5x112 for all. Width, diameter and offset will vary depending on wheels.
For bore would use spigots.
I would like to fill up arches more and Offset is my concern as they are wider then original By chart up to 45 should be ok I guess only on the car I will find out |
Sorry, I mis-understood that you asked for stock figures. Would have been more clear if you asked if the wheels with those parameters would fit on D3?
Sorry
