Old 24th October 2014, 12:00 PM
ricky302 ricky302 is offline
Default Fuel distance till empty
Just filled my 1998 S8 fuel tank to the brim and the computer is saying 255 miles left till I run out, this can't be right surely?
90 litres = 255 miles = 13mpg!.
Is there a way to calibrate this or is something not right?
I own a 1998 Jaguar XJR and a 2001 M3 also and they're nowhere as bad as this.
Old 24th October 2014, 12:08 PM
Hi and welcome to the forum.
If it's like the D3 then you have to drive a bit so the computer can calculate the range based on your current consumption. If you're sat in city traffic then 13mpg sounds about correct.
Matt
Old 24th October 2014, 12:41 PM
The PF D2 was the same, it's based on the last little while of driving, so if you hit a nice long stretch of road, it'll start to climb up.
Old 24th October 2014, 12:44 PM
It calculates that figure depending on your recent driving history: so that suggests that you've just been either:
1 - doing a lot of urban stop/start driving and/or
2 - hoofing it a bit (only you know which…).
It should recalibrate if you then start to drive it on longer runs (e.g. motorways): my wife would typically find that she could drive it for more than a hundred miles before the "remaining range" figure started to fall….
Not the most sophisticated system, but ok once you get used to its logic.
Old 24th October 2014, 04:25 PM
Like said before it depends on recent driving. I have got it showing 150 when flooring it and 500 doing steady 50mph on speed limited motorway roadworks. Under normal circumstances it is showing 300-320 miles on full tank for me.
Old 24th October 2014, 06:19 PM
Cheers everyone, I have only had the car a week and in that time the airbag light came on and it's run out of fuel with a quarter of a tank showing.
Old 24th October 2014, 06:32 PM
sarg sarg is offline
It is 16 years old, any car of that age is gonna have teething problems
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 24th October 2014, 08:18 PM
mannyo mannyo is offline
Running out of fuel is common, how much fuel did you put in to fill up from there. i am guessing the problem is the usual issue with the fuel pump. Sometimes when its replaced, its not seated correctly as its a ballache to do and the result is that the lift pump cannot get fuel from the second half of the tank once the level drops.
Manny
Past
Old 24th October 2014, 08:27 PM
I put in 75 litres to fill it up, I take it since it has a 90L tank 15L is sitting in one of the sides unused?
1990 Nissan GTI-R
1998 Audi S8
1998 Jaguar XJR
2001 BMW M3
Old 24th October 2014, 10:44 PM
I recognise that S8 - did it come from Swindon by any chance?
