#121
Yep - that sounds familiar. Only ever happened to me when (a) it was cold and (b) hadn't been used for quite a while. No issues when without conditions (a) and (b) together, and not recurred since before I mentioned this in my previous post on this thread.
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ). Silent and deadly, and very fast... But not as fast as Ian's M3P- (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ) Green. Fragile, but beautiful. (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
#122
01119 - Gear Recognition Signal 35-10 - - - Intermittent At least I know not to panic...……
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#123
As if it will not do with only one issue, eh?
At least you can use the car while waiting for an opportunity to fix the problems
Johannes _________ Audi S8 -99, Pearlescent, Alcantara/silk napa leather, Burr walnut insert, Alcantara roof lining upper pack A8 32V engine ----- Jeep Grand Cherokee -98 |
#124
Here's hoping it's just the contact terminals that need a clean-up, particularly as this unit was only replaced with a new one in 2017
#125
I cleared an F125 fault on car that had be stood for a while by putting the gear leaver through all it's positions repeatedly but gently at speed. Worth a try if the codes point to the F125 switch.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
#126
Thanks Mike, no VAGCOM here, so can't guarantee it's the F125, but i'm pretty sure that's the case. It was persistently showing this for three days in a row, even with gentle persuasion, which I've not had before. Then it cleared yesterday, and I took him for a good 20 minute drive then, making sure I exercised the 'box without thrashing it, but now it's back again, so I've left him with my local (trusted!) mechanic to see if cleaning the contacts helps.
#127
Stephen, I have VCDS.
#128
I think I may have an F125 issue.
when I put it into D nothing happens. when I press the accelerator, the car thuds into gear... PRNDS is the only option displayed. feels like it then starts in 2nd gear, possibly limp mode, seamless gear changes, reverse not an issue. I have seen the threads re. the F125 removal and replacement, but want to check the connector first. is checking the connector something the can be done 'easily' ie without the removal of brackets, mounts etc ? does F125 have a part number? many thanks
Audi S8 2002 |
#129
Thats a mechanical problem unfortunately, not F125. It'll be going in to 4th gear and not changing.
If it still drives in limp mode then its likely either the first clutch drum thrust bearing, or the o-ring in the same assembly rather than a broken drum. In terms of gearboxes, thats relatively straightforward to repair since its all just behind the oil pump. Getting the gearbox out is more of an ordeal than fixing it - not a driveway job but something which could be tackled by an advanced DIY-er. |
#130
many thanks for your reply.
I am happy to do fluid, brake etc changes but gearbox removal is something I would refer out.. as per your diagnosis, is this something I need to seek the services of a gearbox specialist ? thanks again for your guidance
Audi S8 2002 |
