Old 16th April 2016, 09:59 PM
H-M3 H-M3 is offline
Default tuning box
sorry don't mean to jack this thread, my 4.2tdi has a little box in the engine compartment. its got few switches that you change to fool the ecu i believe? been told they are crap and should just do a remap? any tips guys? NB this tuning box was there when i bought the car.
cheers
Old 17th April 2016, 05:31 PM
tgm147 tgm147 is offline
cheers
Correct. It'll plug into the fuel rail(s) causing the engine ECU(s) to think the fuel rail pressure is lower than it actually is, so that is compensated by raising the pressure in the rail. This gives a power increase and is by no means the proper way to do it at all.
A good remap will always be better.
Old 17th April 2016, 07:08 PM
Default Tune box
Cheers, is it easy to remove this box? Can one with basics remove it?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 18th April 2016, 06:36 AM
1781cc 1781cc is offline
A friend of mine has one in his A7 3.0Q - its pretty simple, once you have located it, pull the plugs to the box, and reconnect the plugs that came out onto themselves so all you have left disconnected is the box and the two plugs connected to it (unless you have a single plug version)
Old 27th April 2016, 09:39 PM
Rick Rick is offline
Warm start up after mod.
Old 28th April 2016, 07:54 AM
ooooh, that sounds beastly!
Old 28th April 2016, 11:00 AM
Norretal's Avatar
Norretal Norretal is offline
Nice..........what option did you go for?
Audi TT - 2015 - Ultra
Old 28th April 2016, 03:16 PM
From the standard headers as i kept the precats, also its an engine out job to upgrade the headers! right back to the standard boxes is all changed. So still options to change the boxes for a deeper/louder sound if i want.
Old 29th April 2016, 07:49 AM
Norretal's Avatar
So that's what it sounds like with both resonators on each side removed
Too loud for me personally, but you said you wanted more growl and you've certainly got that, I hope you're satisfied with your decision? You had new flexis fitted too?
Old 29th April 2016, 10:16 AM
Yeah apparently they make a big difference.
I just gave the man my brief of what i wanted and let him crack on.
