Old 17th November 2017, 06:38 AM
mannyo mannyo is offline
My D3 creaks as well, but only in cold weather. it's just started again this winter having been fine all summer.
Manny
Past
Old 17th November 2017, 04:08 PM
First few minutes these cold mornings but soon retains it's normal quite ride.
Old 18th November 2017, 08:33 PM
lackovicj lackovicj is offline
If someone disconnects the anti-rollbar drop links, you can freely move the roll bar up and down with your hand and feel/hear the same noise.
I lubricated mine with silicone spray but it only lasted a few months.
The bushes are not availabe from Audi as a sperate part, but if you can get after-market ones, I think you can replace them but not 100% sure.
http://www.mister-auto.co.uk/en/bush...7920_g331.html
I had similar squeaky noise from arb..ended up buying 3D printed bushings..as my one had diameter 31mm..easy job to replace bushings even on a drive way.
http://forum.a8parts.co.uk/showthrea...t=13526&page=2
ID:	17498   Click image for larger version
Audi A8 D3 2003 3.7 V8 petrol, Oyster gray with black interior
19" alloy, Sport suspension transmission and seats, HID headlights, Phone in armrest, 4zone AC, Sat-Nav, TV, Dimmable exterior mirrors, VCDS
Previous : Chevrolet Blazer 2001 LT 4.3 petrol
Old 5th December 2017, 07:40 PM
lordchris lordchris is offline
Had this myself last month.
Covered the arb bushes in silicone lub and all gone!
Can be done just lying under it
Old 5th December 2017, 08:27 PM
Johnmed's Avatar
Johnmed Johnmed is offline
It is a sign that cold weather is here once more. Like an autumnal alarm clock. Very quaint.
I had the same thing on my A2, and replaced the bushes, which cured it for one winter before we parted ways.
I’m grateful to ze German engineers for ze alarm.
2007 Mini Cooper S R56
Old 5th December 2017, 08:28 PM
Johnmed's Avatar
Gone,... But just wait. It’ll come back!!
Old 5th December 2017, 08:34 PM
Read it is the same on A8 D4. `bad!
Old 6th December 2017, 04:28 PM
Conquistador's Avatar
Well I'm going to throw a proverbial spanner into the works...
My S8 has had the annoying creaking sound from the front for quite some time now, worse when it's cold as we all know. Had an MOT test this week and it failed on deteriorated bushes on one of the upper arms. They invited me to have a look at them myself and one side was indeed trashed. Nothing left of the rubber bush at all so got the work done to have it changed. Made sense to do the paid of them at the same time as that arm's bush would soon be on its way out too. After soaking overnight with penetrating fluid, the steel bolt was extracted from the aluminium hub, the arms were changed then the car was retested and passed as expected.
I was chatting with the service advisor about the creaking sound I get and he said don't be surprised if changing the upper arms cures the sound. I wasn't convinced and told him I'm pretty sure it's the sway bar. Lo and behold, changing those top arms (they are big!) has cured the creaking sound.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 7th December 2017, 05:24 AM
I must spray it again !
Old 19th March 2018, 08:16 PM
Noise back again again ! Doh
Anyone got part no’s for upper control arm bushes and arb bushes ?
Sounds like Audi don’t see arb ones ?
2005 A8 W12
Previous
2006 A8 4.2TDI
Tags
crunching sound, shock absorbers, suspension
