Old 19th February 2011, 08:37 PM
Originally Posted by IceBlue8 View Post
I think it was a 70's car!
It came out when I was first at university (OK, I'm old - but I don't think there's an age limit here).
Someone will probably come here with the real facts.
83 to 94 god help us!!!
http://en.wikipedia.org/wiki/Austin_Maestro
what the article doesnt explain of course is WHY?????
Old 20th February 2011, 11:39 AM
Thanks Mkoneman!
I wish there was a off-the shelf solution when I fixed mine 2 years ago. I ended up using stainless ball joints, had to cut them and tap them. Audi dealer wanted £160 for new arms & bellows.
Ben, thanks for the heads-up about the flap itself seizing up. Hopefully I haven't damaged anything. Now I see Audi's logic behind using plastic arms.
Name:	S8 new arms small.jpg
ID:	1632   Click image for larger version
Name:	S8 new arms installed small.jpg
Old 20th February 2011, 01:37 PM
I stand corrected! Must have been the Allegro that came out when I was first at University - easily confused; both hopeless cars!
Old 20th February 2011, 11:09 PM
Yes the Allegro was 73 to 83 and frankly was wayy worse even than the Meastro! I mean for feck's sake - whose idea was the square steering wheel on some of them
Old 21st February 2011, 07:22 AM
And the Austin Eggroll was more aerodynamic backwards than forwards FFS!
Old 21st February 2011, 09:02 AM
We had it labelled as the 'All Aggro'
Old 21st February 2011, 09:39 AM
My Dad had one, in a lovely shade of Mustard, with classy matching beige nylon interior, remember that nylon clothes were all the rage back then so the amount of static flying around meant I saved a fortune on perms!!
Audi S8 2002, Black (even the chrome bits)
Audi RS6 Avant 2008, Daytona Grey
Maserati Granturismo 2008, Metallic Nero Carbonio
Old 12th July 2011, 05:23 AM
FireStorm FireStorm is offline
My warranty covers the whole unit with a £50 excess.
would i be better to get the unit replaced for £50 inc labour and new arms, or just buy the aftermarket arms?
and just making sure it covers D3's 4.2s
Old 13th July 2011, 08:43 AM
Just to add my 2p worth.
These things actually make a difference if not working ( if not working properly, they make the car a lot less powerful and it uses more fuel)- and they need to work even for low power settings.
My n/s one was stuck, but when fixed the car was noticably both more powerful and fuel efficient, especially at LOW power levels. ie in normal driving, once fixed, it needed less pedal for the same result.
Both bellows should collapse (and operate the things they're attached to) on startup.
My cars average fuel DIS was 23.1 mpg before I fixed it. Now it's 21.3.
It's done 30,000 miles since I last reset it, so it must be WAY more fuel efficient than it was.
Old 25th July 2011, 09:08 PM
Curtis's Avatar
Curtis Curtis is offline
my car has only one vacum thing,when i start the car it doesnt collapse yet when i rev it it will collapse for a second them go back.is that normal for a pf 4.2?
