Old 16th May 2012, 10:42 AM
Yep, keep meaning to buy a spare for longer journeys.
Old 16th May 2012, 10:56 AM
Originally Posted by IceBlue8 View Post
I'llhave it at £30 if that includes postege.
BTW - the armoured car version will be bullet proof of course!
That jack has a different type lifting point too as it looks more like a standard jack, one that the sill would sit in, it doesn’t look like it’ll locate in the lifting points of the D2. Is it deffo a D2 type or has someone replaced the shockingly ****e one that bent the first time it was used with something from another Audi?
Something else that it is worth upgrading while your at it Jim is the RS6 breaker bar to loosen the wheel nuts. It spins out and extends to give you more torque. I was having a real problem getting a nut out, then noticed it extended and it was out in a jiffy.
I put one of these in the boot too Amar but mine came out of a Toyota i think, very handy to have as i found out. Unfortunately i found out the hard way and acquired the breaker bar after I was caught out. I have however insisted when I have had tyres changed that they leave the wheel nuts just nipped up and I do them up myself in the forecourt with the stock (short) wheel brace in the boot. 2 reasons for this 1, it’s all you got to undo the wheel bolts if you have a puncture. 2, most tyre fitters don’t use a torque wrench properly.
Old 16th May 2012, 11:02 AM
The pressure you can exert on the wheel brace is dependent on
(a) length of the bar and position on the bar force is applied
(b) amount of rotational force applied
Thankfully, the lord made me rather large and heavy, and it seems that in this rare case, my bulk wins over you skinny minnies as standing on any breaker bar has always got my nuts undone...
(oo-er)
Old 16th May 2012, 12:32 PM
christhompson's Avatar
Although as I have discovered, with a long bar for greater leverage it is very easy to turn slightly off centre and the 'key' for the locking nuts slips and burrs the nut. Happily I got it off and back on again, but needed a new set of locking nuts. [oo-er +1]
Old 16th May 2012, 12:43 PM
Yeah locking nuts are only done up just over hand tight on my 8.
Old 17th May 2012, 09:31 AM
Jake242's Avatar
Jake242 Jake242 is offline
(oo-er)
If you need to stand on the nuts to get them off... then you have seriously over-tighten them
I am tightning mine at 120 newton meter and use cobber-grease on them(so they do not rust together in there...
More than 120 nm could damage your alloys I believe(if you stand on it with the weight of 100 kg... I would assume you go between 200 and 300 nm of tight'ning torque)
Just my 2 cent
/Jake
Audi A8 4.2 quattro D2 94' - THE CARRIAGE
Audi A4 1.6 B5 95' - THE LADY IN RED
Opel Kadett 1,2 C 77' - THE CASKET
Old 17th May 2012, 10:47 AM
Just to get technical I think the torque setting for the wheel BOLTS will be an ungreased value, as this is how it would have left the factory. Greased bolts should require less torque, as the tightening of a stud is basically tension, so as it comes tight the bolt stretches and it is this that holds it tight. Lubricated this stretching happens sooner than dry and as such the torque value decreased.
But in the real world it wouldn't make much difference on a wheel stud and nut or wheel bolt. And wheel nuts / bolts should be checked weekly.
