Gearbox - limp home mode grrrrrr
Hello to all. My old girl is an A8L FL 2000 model, 4.2
Can anyone offer advice with regards to the A8 gearbox entering limp home mode? I was just outside of Gatwick and went to pull away at the roundabout. I heard an enormous thump and lost drive. Put my HWL on and then noticed all red lights ablaze on the dashboard (PRND432). I managed to pull away with about 2000 rpm (going nowhere fast) and managed to get back to a friend's house. I noticed a couple of days ago a slight non-output of power when changing gear. MY gearbox has always thumped a bit when drawing up to a junction, I suspect when changing down from 2nd to 1st gear. Nothing since apart from today's experience. First off, I'm going to try to get back home which is a 15 mile journey. Is there any danger in attempting this? Secondly, will a gearbox fluid change help in any way or am I going to be throwing money away? I say that, because I read something on Paul Waterloo's audipages.com site about something similar and the chap in question managed to fix his problem with a fulid change. That would be a right result compared to the cost of either a repair or reconditioned gearbox. If a gearbox recon looks like the only option, does anyone have any recommendations for companies in the South London/Surrey area? Thanks in advance for any insights or assistance. |
Hello John, really sorry to hear that. Presumably this is the car that's been off the road "in protective custody" for so long.
I guess the first thing to do is get VCDS plugged in and see what that reveals, but it doesn't sound good. Based on various threads here there ought to be a viable business rebuilding these boxes as they do seem to be the "A8 killer" in many cases.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
If you value your car don't drive it. Put it on truck and bring it to ZF specialist. I can recommend Chester Transmissions. I predict it will be full gearbox rebuild.
Another option is finding the same model of used gearbox and finding someone to help you swap it.
I'd rather drive on left |
There are normally two specialists recommended on here, but neither are down south:
1 - Chester Transmissions - as mentioned (in Chester, unsurprisingly!) 2 - Mackies, in Glasgow. I've used both. Chester did the gearbox flush, which made the problem much worse (a common result, from other's posts on here, and not their fault). I then drove it (VERY carefully…) to Glasgow, where Mackie's rebuilt it, perfectly - but expensively. I chose Mackies over Chester due principally to the quality of their guarantee - 100k miles on the rebuild |
Codes 17114 and 17117
Got the car back home late last night, and ran it through on my cheap £20 reader which showed the two fault codes, 17114 and 17117. I'll probably go for a fluid change first to see what good that does, if any.
I'm going to try and investigate some more 'local' options first while the car is off the road for the time being. Thanks to everyone that chipped in, and I'll post back here if I have any news. Nothing is going to be happening on that front until Thursday, when my current shift ends. |
17114 is gear monitoring, incorrect gear ratio.
17117 is also incorrect ratio for 3rd gear. Reading elsewhere the only cure maybe a transmission rebuild, choose the specialist wisely.
Tags |
gearbox limp home a8l fl |
