D3 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Hi Ray,
Glad to hear that it's back up and running again. If it's the same place the flashed the original ecu then I would be inclined to give them nothing as its most likely them that fried the ecu by not having power supply connected during the flashing. If anything I would be asking them to pay for the ecu that you bought.
Del |
As promised took her back this morning.
They plugged in their laptop and it read the ECU details. The resultant file was sent to the programmers. Modified file returned and they attempted to load it into the ECU. It failed to write, claimed loss of communication via the OBD port. I left the car with them and called for it some four hours later. They had managed to do the reprogramming by opening the ECU and doing it on the bench. The car is now running properly . Let's see how long for. The programming company people say there must be a problem with the OBD plug, and also said not to plug the diagnostic kit into the OBD in case it screws the ECU. Anyone had a problem like this?
There are ecu's that require programming on the bench but I am surprised that yours needed it.
I think connecting vcds is not going to be a problem as the gateway is communicating with the ecu on your behalf as it's not a direct connection.
Del |
Set of at silly o'clock yesterday (Saturday) morning.
The car drove like an A8 all day. M6/M5 south, cut off to Cirencester for a Little Chef breakfast,. Bummer, Little Chef is gone, now a petrol station and a sign pointing to a McDonalds. Drove to Gloucester, did some shopping. Then continued along the A48 to Chepstow. Had lunch at the Beachley Ferry Inn. Then we drove back to Manchester via M4/M5/M6 for a family gathering dinner in The Trafford Centre, and eventually back home. As said before the car was great!!! Now the probs. This morning I have plugged in VCDS and as expected, nearly five Zillion fault codes. Tried the "clear all codes" option with engine running. Switched off and restarted the car. Did another "Auto Scan" and after a quick perusal there seems no difference in faults reported. SWMBO wants to go to Southport so bang goes another day to frivolous women things. Just for fun here is my log:- (pick the bones out of this) Sunday,15,March,2015,11:25:03:58733 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.2.0 (x64) Data version: 20150311 www.Ross-Tech.com VIN: WAUZZZ4E14N025504 License Plate: KR04 AUD Mileage: 198530km-123360mi Repair Order: Test 03 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1E 25 34 36 37 38 42 46 47 4F 52 53 56 57 61 62 67 72 76 77 VIN: WAUZZZ4E14N025504 Mileage: 198530km-123360miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Not registered 0001 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4E0 910 401 H HW: 4E0 907 401 B Component: 3.0L V6TDI G000AG 0050 Revision: --H01--- Serial number: AUX3Z0D3139689 Coding: 0011773 Shop #: WSC 66565 257 00032 VCID: 204FCCB5F3268E214EF-8075 7 Faults Found: 18278 - Transmission Mount Valve 1 (N262) P1870 - 001 - Open Circuit - Intermittent Freeze Frame: RPM: 840 /min Torque: 70.2 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 11.78 V Bin. Bits: 00101100 Torque: 261.3 Nm Temperature: 33.3°C 18057 - Powertrain Data Bus P1649 - 001 - Missing Message from ABS Controller - Intermittent Freeze Frame: RPM: 1155 /min Torque: 0.0 Nm Speed: 76.2 km/h (no units): 11.0 Voltage: 14.52 V (no units): 0.0 Bin. Bits: 00000000 Temperature: 84.6°C 29698 - Please Check Fault Codes in Comfort System Control Module (J393) U1002 - 001 - - Intermittent Freeze Frame: RPM: 1155 /min Torque: 0.0 Nm Speed: 3.4 km/h Duty Cycle: 1.0 % Voltage: 14.44 V Bin. Bits: 11001000 Torque: 257.4 Nm Temperature: 84.6°C 16885 - Vehicle Speed Sensor P0501 - 004 - Implausible Signal - Intermittent Freeze Frame: RPM: 1176 /min Torque: 0.0 Nm Speed: 3.4 km/h Duty Cycle: 2.0 % Voltage: 14.59 V Bin. Bits: 11001000 Torque: 253.5 Nm Bin. Bits: 00000000 17084 - MIL Request from Transm. Control Module (SAE) or Control Module Defective (VAG) P0700 - 002 - - Intermittent Freeze Frame: RPM: 0 /min Torque: -195.0 Nm Speed: 0.0 km/h Voltage: 11.86 V (no units): 0.0 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 17610 - Fuel Injector for Cylinder 2 (N31) P1202 - 001 - Electrical Malfunction - Intermittent Freeze Frame: RPM: 1638 /min Torque: 444.6 Nm Speed: 37.0 km/h Inj. Quantity: 59.3 mg/str Voltage: 14.14 V Pressure: 1462.6 bar Temperature: 20.7°C Temperature: 52.2°C 17609 - Fuel Injector for Cylinder 1 (N30) P1201 - 001 - Electrical Malfunction - Intermittent Freeze Frame: RPM: 1638 /min Torque: 444.6 Nm Speed: 37.0 km/h Inj. Quantity: 59.3 mg/str Voltage: 14.14 V Pressure: 1462.6 bar Temperature: 20.7°C Temperature: 52.2°C Readiness: 0 1 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4E0 910 156 F HW: 09L 927 156 Component: AG6 09L 3.0lTDI RdW 0100 Revision: 00000001 Serial number: 0018492 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 2541DDA1EC046B093D9-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 M Component: ESP 5.7 allrad H44 0500 Coding: 0008357 Shop #: WSC 00196 000 00000 VCID: 224BC6BDFD2A9C3158B-8077 6 Faults Found: 00003 - Control Module 014 - Defective - Intermittent 00003 - Control Module 014 - Defective - Intermittent 00003 - Control Module 014 - Defective - Intermittent 00003 - Control Module 014 - Defective - Intermittent 00003 - Control Module 014 - Defective - Intermittent 00003 - Control Module 014 - Defective ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D3139689 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58BFA455EBF606E176F-800D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670112 Shop #: WSC 02313 785 00200 VCID: 2345C3B9E230953953D-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300DE047535272 Coding: 0000002 Shop #: WSC 00196 210 83196 VCID: 3A7B1EDD75BAF4F160B-806F Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 322DP047506758 Subsystem 3 - Serial number: 7420.04.040000000000010056˙ Subsystem 4 - Serial number: 010056˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 A HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0300 Revision: 00000025 Serial number: 00000000042459 Coding: 1067009 Shop #: WSC 02311 785 00200 VCID: 1B35FB59DA40ADF99BD-804E 1 Fault Found: 01858 - Air Outlet Sensor; Right Center (G348) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 4 Reset counter: 202 Mileage: 197100 km Time Indication: 0 Date: 2015.02.21 Time: 05:49:43 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 J HW: 4E0 907 279 J Component: ILM Fahrer H12 0190 Coding: 0101104 Shop #: WSC 02313 785 00200 VCID: 2F6D3F89BEF82159C75-807A Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000019 Shop #: WSC 02313 1 Fault Found: 02071 - Local Databus 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 1 Fault Frequency: 5 Reset counter: 199 Mileage: 197588 km Time Indication: 0 Date: 2015.02.22 Time: 11:17:56 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000501 Serial number: AUZ5ZBD1036835 Shop #: WSC 00000 000 00000 VCID: 1C37F845DF4EAAC1927-8049 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 63C583B9A2B0D53913D-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112041 Shop #: WSC 02311 785 00200 VCID: 65C19DA1AC84AB09FD9-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H04 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 AX Component: KOMBIINSTR. VDO H54 0090 Revision: D21 Serial number: AUDID3F7000065 Coding: 0000403 Shop #: WSC 00196 067 57207 VCID: 5CB7B8459FCEEAC1527-8009 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 168806 km Time Indication: 0 Date: 2013.02.08 Time: 07:16:42 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 HW: 4E0 815 069 D Component: Heizgeraet H06 0300 Revision: 0000000G Serial number: 00000009001484 Shop #: WSC 00000 000 00000 VCID: 59B9A15190FC1FE9491-800C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 16003043270643 Coding: FCFE5BDE2B7504 Shop #: WSC 00196 210 60652 VCID: 65C19DA1AC84AB09FD9-8030 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 169 Mileage: 198539 km Time Indication: 0 Date: 2015.03.15 Time: 11:21:35 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B552B994AE05D79EBD-807E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D3139689 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58BFA455EBF606E176F-800D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B093D9-8070 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670114 Shop #: WSC 02313 785 00200 VCID: 2345C3B9E230953953D-8076 2 Faults Found: 01877 - Belt Height Adjustment Button (E333); Down 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 4 Fault Frequency: 4 Reset counter: 169 Mileage: 197804 km Time Indication: 0 Date: 2015.03.07 Time: 08:23:50 01876 - Belt Height Adjustment Button (E333); Up 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 4 Fault Frequency: 4 Reset counter: 169 Mileage: 197804 km Time Indication: 0 Date: 2015.03.07 Time: 08:23:50 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H43 1060 Revision: 00000000 Serial number: 353DJ047514344 Shop #: WSC 02313 785 00200 VCID: 3B751BD97A80CDF97BD-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000409300093 Coding: 0035968 Shop #: WSC 02313 785 00200 VCID: 1D31F541C454A3C9659-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E2 959 802 Component: Türsteuer.FS BRM007 0110 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 5EB3B24D89D2F8D13C3-800B No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040404210211 Coding: 0004345 Shop #: WSC 02313 785 00200 VCID: 275DD7A9960879190F5-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0460 Revision: PROD_01 Serial number: 00000000001459 Coding: 0000013 Shop #: WSC 02313 785 00200 VCID: 2A5B2E9D851A447110B-807F No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000038976 Coding: 0010001 Shop #: WSC 02313 785 00200 VCID: 1E33F24DC952B8D17C3-804B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E2 959 801 Component: Türsteuer.BF BRM007 0110 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 5EB3B24D89D2F8D13C3-800B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000221 Shop #: WSC 00196 067 57207 VCID: 204FCCB5F3268E214EF-8075 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 122 Mileage: 196584 km Time Indication: 0 Date: 2003.10.08 Time: 00:04:08 Freeze Frame: Voltage: 11.90 V Count: 61 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 B Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304DV047586477 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 316939F1A8CC37A9D11-8064 1 Fault Found: 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 12 Reset counter: 209 Mileage: 197033 km Time Indication: 0 Date: 2015.02.20 Time: 10:11:12 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 G HW: 4E0 919 146 Component: TV analog TUNER H12 0300 Revision: 00000085 Serial number: 00000000002193 Coding: 0001003 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B093D9-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0160 Revision: 00000000 Serial number: 00000000010676 Shop #: WSC 00000 000 00000 VCID: 5DB1B54184D4E3C9259-8008 Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 301008802E Coding: 303030393135313035414B56413033303130303838303245 Shop #: WSC 73430 210 01865 5 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 201 Mileage: 197806 km Time Indication: 0 Date: 2015.03.06 Time: 16:41:15 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 6 Reset counter: 255 Mileage: 197806 km Time Indication: 0 Date: 2015.03.06 Time: 18:38:11 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 12 Reset counter: 255 Mileage: 197806 km Time Indication: 0 Date: 2015.03.06 Time: 18:38:21 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 12 Reset counter: 255 Mileage: 197806 km Time Indication: 0 Date: 2015.03.06 Time: 18:38:31 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 7 Reset counter: 255 Mileage: 197806 km Time Indication: 0 Date: 2015.03.06 Time: 18:38:41 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM007 0110 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 5DB1B54184D4E3C9259-8008 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000404010011 Shop #: WSC 12336 024 394758 VCID: 36630AED41A21091843-8063 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM007 0110 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 5DB1B54184D4E3C9259-8008 2 Faults Found: 01482 - Motors for Central Locking 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 2 Fault Frequency: 2 Reset counter: 207 Mileage: 198480 km Time Indication: 0 Date: 2015.03.14 Time: 17:27:38 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 207 Mileage: 198480 km Time Indication: 0 Date: 2015.03.14 Time: 21:56:40 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08730410704141 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 2149C9B1F82C8729411-8074 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 B Component: TELEFONMODUL EU 0770 Revision: 00000006 Serial number: T2AUD31011HBH0 Coding: 0000004 Shop #: WSC 02313 785 00200 VCID: 224BC6BDFD2A9C3158B-8077 No fault code found. End-------------------------(Elapsed Time: 03:10)--------------------------
I have had problems with a 2007 A8 not clearing all and had to do them individually - very annoying and have complained to VCDS about this. There is a check box which you need to select but i have still found it to be an issue.
Is that the little chef by the bp garage just off the A419 / Fosse Way that's closed Ray? I'd be amazed if it has, I went in there not that long ago (about a week) and as it is right next to a travel lodge it gets used for breakfast etc. are you thinking of the one that used to be about 2/3rds of the way towards Cirencester from Gloucester at what used to be another service station as that's been closed for years
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
It has been 40 years since I was in the area so looked it up on the useless tinternet. Little Chefs are closing pretty quickly and SWMBO is angry. It was on Burford Road, just of the A417. The address on the Little Chef web page was wrong. We had been to Birdlip, the boss had never been there, then via the A417 towards Swindon. Turned right towards Cirencester on the A429, garage on left.
Now with your advise I have found the correct location. Same junction, turn left away from Cirencester and at the first exit there is travelodge and Little Chef. SWMBO has just beaten me up and said that I am a Banker. I should of gone into the garage and asked. In future I will ask on THIS forum before I leave the house
That's the one Ray yes - so close but no cigar! Sorry about the domestic lol
Just had a big grin from my good lady.
Yippeee!! I am forgiven. I'm due to visit Guy in the near future so will be giving another try at finding it. Having a cuppa then taking her indoors for some shopping then we have to collect the basset from the kennels, he had a weekend there, spoilt rotten he is. On the way SWMBO has promised me a Little Chef breakfast at the Haydock site. It is on the A580 East Lancs Road and we see that one a few times a week so no let down.
On the subject of Little Chef, we randomly found one just North of Stoke last Autumn, I think it's called Talke, junction of A34 and A500 next to a Travelodge.
We were on our way from the Lake District to Leicester, avoiding the usual car park on the M6, and were in need of "sustenance". Did the job. Looking at maps, there seems to be another just a couple of miles away by the M6/A500 junction.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
