Old 28th July 2011, 05:11 PM
injector 5 fault or lean fault?
Old 29th July 2011, 02:02 PM
reiss reiss is offline
running too lean fault
Old 29th July 2011, 04:42 PM
Check the fuel pressure.
Maybe it is time to take it back to whoever did mapping and ask what they think. I am sure they can switch back to original map and then back to economical again to confirm or rule out mapping issue for free or a small fee and modify map if required. They might even point out the fault while doing it.
Old 5th August 2011, 02:52 PM
cant get hold of the person who mapped the car so does anyone have any suggestions as to what to do? ive contacted audi and they wont flash my ecu back to standard map
Old 5th August 2011, 04:04 PM
have you checked fuel pressure?
Old 8th August 2011, 08:56 AM
No how do i get that checked?
Old 8th August 2011, 01:35 PM
Depends on year and engine code, here is pdf with example for BFM and BFL engines
Old 17th August 2011, 06:42 PM
right ive put original map back on and the light stayed off for 400miles and its come on again! any suggestions before i take it to audi to fix and rip me off???
Old 17th August 2011, 08:27 PM
Which fuel have you ran for the 400 miles?
Old 18th August 2011, 09:25 AM
i always run it on shell v power
