Old 10th April 2015, 12:24 AM
tipptop tipptop is offline
So I finally got it sorted. Such a contrary system. All I did was run the pad change opening and closing procedure again, then the pad thickness adaptation, then the function test. Then I tried to clear the code again and it cleared. Then when I killed ignition with the stop button, there was a satisfying whirr from the epb motors as they did the final calibration.
So for anyone else that stumbles across this problem,
Follow the procedure outlined in the ross tech video.
If you can't clear the 02596 code and the final calibration doesn't happen after you kill ignition then:
Cycle epb on then off again.
Open epb fully in basic settings, group 007, wait 30 seconds then close controller.
Close ebp fully in basic settings, group 006, wait 30 seconds then close controller.
Put in new pad thickness in adaptation, group 006, test, then save.
Run function test in basic settings, group 010, ebp moves in and out 3 times, wait 30 seconds then close controller.
Then open epb controller and try clear the fault codes, if they clear then close vcds, turn off ignition, lock steering.
You should now hear the motors do the final calibration.
Loudly curse about the hours you've lost with this pernickety system.
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 10th April 2015, 09:23 AM
Glad you got it sorted
Old 10th April 2015, 06:55 PM
Burnzybubbles's Avatar
If you read the ross tech notes on this it does say you need to follow the procedure by the letter, silly sausage lol! Atleast it's all done now and your driving happy
Old 10th April 2015, 07:13 PM
Am, I did follow it to the letter... I had to re-do the entire process as if I was changing the pads again to get the code to clear.
A6 C5 1.9tdi 2004
Old 10th April 2015, 10:04 PM
Just re read through the document and seen how it can be interpreted differently, when I was reading the document it read as a whole process, the first two where sub options for whether I wanted to pad change or repair, then I followed the procedure i.e closing calipers then function test, not just follow certain steps of the process, I know when I did mine I followed it to the letter but I also had problems and I was still starting from the beginning I.e from opening the calipers, mine wouldn't do a function test to begin with, can't remember how I overcame it I think it just played ball then took the adaptation once it cycled.
Old 11th April 2015, 06:45 PM
Yeah I get what you mean its down to interpretation. I did the process as ross tech said, however when I met bother clearing the fault codes, ross tech advised just to keep doing the adaptation and function test until everything works out, they don't say to repeat the opening and closing again, just the adaptation and function test. Hopefully this helps someone else in the future.
A6 C5 1.9tdi 2004
Old 18th July 2015, 01:16 PM
munchkincoupe munchkincoupe is offline
I have this issue on my 2005 3.0tdi - rear pads changed 2 months ago and I've just been driving it since as I really haven't the time to sort it. The EPB works. Rear brakes are engaging and I've tried the processes at a friend's garage with his scanners last week but I'll give it another shot through the whole process as you guys have stated above.
My question is this - with the pads having been fitted for 8 weeks what pad thickness size should I put in for the adaptation please?
Old 30th July 2015, 07:53 AM
Right - I went back to my friend's garage yesterday and connected up his Omniscan unit. Went through the processes outlined above. I can get the the brakes to open and close and then go to adjust adaptation levels but then when I get into the function test it does nothing?
The brake pad light is still on, the rear brakes recalibrate when I take the keys out and the EPB is working but still got the same fault code too?!?!
Old 30th July 2015, 05:36 PM
I'll guess only a very few will be using omniscan, pretty much standard on here to be using vagcom, if you doing everything BY THE LETTER, and it's still not working then I'd try getting hold of someone's VCDS first before going any further.
My car didn't do anything on the function test iirc and I can't remember what I did to make it work I think it just started working after messing around a bit, and make sure you cycle the EPB before starting the procedure.
Old 31st July 2015, 08:26 AM
I'm going to book a mobile tech to come round with VCDS - thanks
