#31
It'd involve cutting holes in the body of the D2. The D3 holes are already there and the hinge mechanism is quite different if I remember rightly
#32
or maybe some kind of adapter plate could be made to utilise the same holes and welded to the D3 bracket
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
#33
I definitely don't want any holes in my car
Another idea. In D2 we have two standard struts: 4D0 827 551 B Length : 403.5 mm Outer Diameter 1 : 8 mm Outer Diameter 2 : 19 mm Eject Force : 310 N Stroke : 161 mm As you see, eject force is relatively small for strut of this size. The idea is to custom order struts with higher eject force so that the boot will open 'automatically'. But there's a risk: If the struts are too powerful they will make the lid fly into the rear windscreen, damaging everything, including hinges. Also, strut power varies with temperature. They are stronger in summer and weaker in winter. But it maybe worth trying! Here's a video of installing stronger struts. It is for Golf and there's no risk of hitting rear windscreen, but take a look: http://www.youtube.com/watch?v=7RgZTIMsJLc Now for D2 we can order custom made stainless steel (!) struts with variable force, which means they will fill it with gas to maximum, and we can then reduce eject force to desired level with a supplied valve. They can be re-gassed to maximum again if sent back to manufacturer. Take a look here: http://www.strutsdirect.co.uk/compon...gas-struts.php I want to order it just because it's stainless steel! Model SDSS-02 will maybe work for us in terms of geometry and it is capable of 75 - 650N eject force range, which is up to twice stronger than our struts. Fully custom config is also orderable: http://www.strutsdirect.co.uk/compon...gas-struts.php I would try this approach before cutting any holes. And I guarantee it'll be dead quiet comparatively with motors stuff! ...If it'll work in principal of course...
I'd rather drive on left Last edited by notorious; 17th August 2012 at 12:39 PM. |
#34
Stronger struts might push it open but it might fail to open at all because of higher tension to the lock it might not disengage to allow opening. And when it's open you will need extra force to close it.
#35
Sure, I take these concerns on board. All these ideas should be tested. And yes, you still have to close it manually.
I'd rather drive on left |
#36
I'm not going to try the stronger struts, that does nothing to make this work as I want. I'm not opposed to cutting one or two small holes though. What I'd like to do is perhaps build a hybrid hinge using the D2 and the D3 hinge, and use the D3 motor. I think I could make a tidy little setup that way.
#37
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
#38
Thats odd its working fine for me, just tried it
#39
How weird. Still not working for me. Could you post the URL as it is when it works for you, please?
#40
http://www.vagcat.com/epc/ But you must register and sign in to the forum first so if you haven't done so then try setting up a user ID and password first.
