Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 9th June 2016, 03:07 PM
what version was that then, i thought you were doing 770
i told them that after the update i was expecting to see the Audi connect icon on the main menu, when he came back to me he said "we managed to get the icon you wanted we have put the engineer menu on for you we cant get google earth to work"
it did however work as soon as i got in the car, so i think they did enable something in the hidden menu, they just didnt know it.
first thing to check if its still not there is hidden menu under GEMMI, make sure its activated.
have a look in nav/settings - see if you have the google earth option under map types
Old 9th June 2016, 03:11 PM
Yup, 770.
Audi Connect icon has been there since the update, and is greyed out until my rsap connects, then its happily selectable.
There is no 'map type' in the sat nav settings.
Wonder if I need a newer map ??.
Doesn't explain where wifi went though.
So, no down sides to doing the upgrades, but no upsides yet either !
Old 9th June 2016, 03:17 PM
took me a wile to find the wlan, its somewhere stupid like in the media sources or bluetooth
so def need to liven up the gemmi then , that will give you the extra menus
Old 9th June 2016, 03:27 PM
I had already tried starting it, but no joy..... (green menu worked fine after the update to 770, but not before)
I've run out of time for today, might have to be a weekend play....
Old 9th June 2016, 04:10 PM
ok will check out my notes on hidden menu and see what else i can find
Old 9th June 2016, 10:14 PM
Ta...
Old 9th June 2016, 10:18 PM
If it helps my coding is:
Code:
Coding: 020101000001F9EF7516AB1E00000003000001000000000000
Old 12th June 2016, 09:12 AM
heres a couple of things to try
The WLAN settings are / should be in Telephone settings, also under media as an option to connect to
Green menu
/diagnose/settings/wlan_settings
WLAN activation can be enabled here
/diagnose/settings/tel_settings
Nad Activation (puts google logo on menu)
may also allow you to choose what to use as phone and which for data,
/diagnose/settings/ami_aux
set AMI and AMI BT to enable if they arent already
Old 12th June 2016, 09:25 AM
i also think you may need something from menucaroperation but lets see if the others do it first
Old 13th June 2016, 12:16 PM
Sorry for late reply.... Busy weekend.
I got WLAN working
I had to go to the media section first, and enable wifi from there, which then caused the telephone menu to activate meaning I could control it
Really, really unintuitive, but works fine. Paired up my laptop to the hotspot no probs.
Still no google maps though. Started it through the green screen, and restarted it, disabled, re-enabled, but nothing.....
Still. I have wifi, and that's a big rSap bonus...
