Old 31st March 2013, 08:29 PM
Ah, but when they match the Xenons no-one notices one missing.
Old 31st March 2013, 08:52 PM
Then perhaps remove both bulbs and solve problem that way?
Old 28th May 2013, 10:18 PM
rs32 rs32 is offline
hello all - new to the forum and hoping to switch to a 2002 S8 in the next few weeks from my current BMW E39.
Having a slight panic about a car I've seen not having xenons - but have read here and elsewhere that all 2002 S8's had them as standard - could someone please confirm.
Made the mistake of thinking I could get away with aftermarket HID on my current car and won't be doing that again
Many thanks
Old 28th May 2013, 10:23 PM
Hi RS32, welcome to the forum.
I can't confirm that all 2002 S8's came with xenon as maybe there was one idiot who ordered car without xenons or downgraded. I'd recommend 'xenon pluses', also known as bi-xenons: http://forum.a8parts.co.uk/showthread.php?t=2265
Can you post a link to the car you've seen? S8 without xenons is a strange combination...
Old 29th May 2013, 05:08 AM
Welcome from me too. I'm sure someone who really knows will answer your question, but I've not seen a late S8 without Xenons either
Old 29th May 2013, 07:43 AM
thanks for the friendly welcome
(sorry no ad available) - but the car I've seen doesn't have the twin circle lights on the inner edge - just the "normal" projector-style lenses.
I'll check when I go see it again for the metal ballast boxes and hi-voltage stickers. Hopefully it's OK !
Old 29th May 2013, 07:45 AM
Does it have headlight washers? If so it's likely to have xenons of some description - either bi-xenon which have the tiny sidelight built into the top inner corner and the diagonal lines visible across the lens, or regular projector style dipped xenons with regular high beam.
Old 29th May 2013, 07:55 AM
from memory yes it does have the washers, or at least it has the cutout panels (colour-coded) in the front bumper.
going to see the car again in a few days so will triple-check to avoid disappointment. hopefully within a week I'll be able to put some pics up !
Old 29th May 2013, 08:33 AM
Cutouts in the bumper are for the pop up washers - early cars have fixed washer jets. You'll soon know when you switch them
Bi-xenons are not a cheap retrofit unless you happen to find someone breaking one on ebay who doesn't know what they cost from Audi if you break one!! They are nice to have but as long as it has factory xenons of some type I'd just live with it.
Worth putting some more details up of the car you're considering if you want any views on condition/issues/if the car is known
Old 29th May 2013, 10:02 AM
Check if it has self-levelling lights, if it does, i.e you cannot adjust the beam positioning by selecting 0,1,2,3, then chances are it has Xenons. If it is an S8, it should have Xenons.
