Old 17th June 2016, 03:22 PM
Originally Posted by muj33b View Post
Hi sorry If this may sound silly but if I don't have the red connector and don't have av option when I press cd/TV button then does this mean I cannot install this bluetooth adapter???
Hello, you said you don't have a TV in another post, so neither the wiring nor the TV that acts as an analogue audio-MOST interface will be present - sorry.
Old 19th June 2016, 10:20 AM
muj33b muj33b is offline
Thanks for the reply snapdragon, if anyone is interested in the Bluetooth reciever then I have 1 of these brand new.
Old 14th July 2016, 08:08 AM
mmarksx19 mmarksx19 is offline
Originally Posted by mmarksx19 View Post
Fitted everything last night.
Only issue I had was that the black connector didn't slide out of the red cover - I had to use a dremmel on the end to remove a tab and force it out but all went back together perfectly.
Works a treat. volume is lower than other sources (radio, TV etc) but that might be my phone.
Of course not as clever as a full AMI install in that all control (other than volume) is via the source rather than the car controls but at 10 of the price it works!
Michael
I have tried 2 different phones now and have the same issue. Normal radio volume is great but as soon as I use AV1 (wqhere the BT100 is connected to), I have to have the volume on almost maximum.
Any thoughts?
2007 A8L 3.0TDi
Old 14th July 2016, 03:20 PM
چان یظہ پلہگ سظمعتهئنگ علسع
Whoops! can you plug something else into AV1? such as mobile phone with headphone to phono lead? You can get them from poundlands or supermarkets. Play music on the phone via a cable and see if it is normal or quiet.
