Old 31st January 2021, 10:44 AM
The front panel in that pic was developed to allow fitting the VR6 in to a B5 so it moves everything forward and gets rid of the bulkiness of the factory panel. Possibly with the same treatment in a D2, and losing the AC, it might fit.
Old 31st January 2021, 12:04 PM
S81 S81 is offline
Do they change transmission ,drives ,and some suspension to allow it to cope with the power and weight ,my dad had a range rover many years ago and the original petrol engine was removed and a turbo charged diesel was installed and she spent more time in the workshop that on the road ,.mainly clutch ,gearbox and leaks
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 31st January 2021, 12:37 PM
That A4 is using the 01E 6-speed manual which can be fairly easily bulletproofed, and with work can take 1000hp, although yes clutches get to be a challenge at that level. However, clutches in the 500-600hp range are easily available, derived from the RS4 and related things. The B7 RS4 clutch should take the V10s 450hp easily enough.
The D3 uses the 6HP series of transmissions which are bigger and stronger, but the 6HP26 fitted to the larger engines has a completely different architecture to the 5HP in the D2 - the engines are moved back in the D3 bay by 4-5" or so to improve weight distribution, hence they can accommodate an extra cylinder. To put it in the D2 would need the 01E manual again, pushed back as far as mounts and shafts can accommodate, but because the D2 is based on the 5HP the engine can't go back anything like as far as it can in the D3 because the bulkhead and HVAC are in the way, so the room needs to be found in the front.
With that much engine in front of the axle it would be an autobahn cruiser. You'd have to apply in writing to change direction
Old 31st January 2021, 02:13 PM
S81 S81 is offline
So you would really only do it to prove that you could,even to buy a good v10 engine must be 5k + I'm guessing
Daily driver
Previously owned
Old 31st January 2021, 02:41 PM
Yeah pretty much. There are easier ways to get 450hp for sure. It'd be different, but I'm not convinced its worth the effort.
Old 31st January 2021, 08:14 PM
Audifan Audifan is offline
Have heard of people using a 50/50 mixture of engine oil and diesel fuel to do the flush. As to whether either option is wise or advisable, I'd leave that to the expert on here to comment on... calling MJ
I re-watched the video and he said diesel oil not diesel fuel. He also used seafoam and here is a link to it.
Old 31st January 2021, 08:17 PM
V10 in a B5 A4...
Wow that's crazy
Old 31st January 2021, 08:28 PM
Don't know about USA but here these days pretty much all engine oils are made for use in both petrol and diesel engines. In the old days when diesel fuel contained much more sulphur there was more sulphur neutralising additives in diesel oil. These days there is virtually zero sulphur in diesel and all oils are much better so there is no need for specific diesel oils.
