Old 31st July 2021, 09:53 AM
Default Every day is a school day...
"percussive maintenance" - the thing you do to cars when WD40 doesn't work
Old 31st July 2021, 12:55 PM
To me, the phrase “percussive maintenance” encompasses a whole spectrum of violence from a gentle persuading tickle to walloping the crap out something. This must be why the extended hammer family in my garage is 17 strong….
Pleased to see that I’m not the only one that thinks that reclaiming perfectly good parts from an otherwise useless assembly is a reasonable thing to do….
Nick
Old 31st July 2021, 04:15 PM
Audifan Audifan is offline
Five original Avus 1 wheels with centre caps These were actually the reason I bought the car since they are so rare. Even if the car turned out to be a lemon, it was worth buying just for the wheels. These are in for refurb while its on the lift
What is the part number to these Avus wheels?
Old 31st July 2021, 05:14 PM
Question for those more knowledgeable than me on the PF: is the inlet manifold different between A8 (AEW / ABZ) and S8 (AHC)?
Back in the Audi world after a 2-week absence..... and so nostalgic to see a high-spec late PF S8.
As for the inlet manifold, I may be wrong but I though the PF had the 2-stage flaps whereas the PF A8s only had one flap and a simpler flow. Though I also recall from ages ago reading something that said that actually on an S8 both flaps move at the same time anyway, so there was no "intermediate" flow.
(Subject to derision and destruction by someone like IT......)
Old 31st July 2021, 07:53 PM
I don't know as they're not back from refurb yet. I'll check next week when they're back
FL manifolds have flaps - the S8 has a single actuation point which opens both sides at once. The A8 has two stages, but I've never looked in one to see how they are actuated.
All the PF manifolds I have here have a rotating centre section which opens and closes different paths in the manifold. Whether the S8 version is different, I don't know - there is nothing visually different between them. That may mean I have a bunch of A8 manifolds of course.
Old 31st July 2021, 08:41 PM
Part number here, from when I sold a set ages ago (2015), 4D0 601 025N http://forum.a8parts.co.uk/showthread.php?t=9858
Old 31st July 2021, 09:00 PM
Removed the inlet manifold
The engine in the maximum taken-apart-ness
Flipped over with the sump removed - fairly clean inside
Opened up the first expensive box of bits. There are several boxes!
Hurrah for having an actual sump gasket instead of silicone! I still used some blue Hylomar to help it though
Sump back on. This was in remarkably good condition compared to the recent FLs which have all needed blasting and powdercoating.
This is one of my favourite bits of the AHC. We need more valve lift to get more airflow, so just mill pockets out of the heads so the massive cams can fit!
Cam covers back on with fresh gaskets
Thats it for tonight. Inlet and front gubbins back on tomorrow.
ID:	26837   Click image for larger version
ID:	26838   Click image for larger version
ID:	26839   Click image for larger version
ID:	26840   Click image for larger version
ID:	26841   Click image for larger version
ID:	26842   Click image for larger version
ID:	26843   Click image for larger version
ID:	26844   Click image for larger version
ID:	26845   Click image for larger version
ID:	26847   Click image for larger version
Old 1st August 2021, 05:19 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
When the gearbox was done the cam position sensor was refitted with the cable sitting on the exhaust manifold instead of behind the heat shield! How it was still running is a mystery.
Surprised there wasn't a bottle of the attached in the glove box with the car
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 2nd August 2021, 02:36 PM
No timing chain tensioners? less to go wrong as opposed to the 40V?
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 2nd August 2021, 08:14 PM
No chain tensioners, no secondary air, no secondary O2s. Nice and simple and mostly bulletproof. It was a pretty expensive engine to make with lots of complicated castings and machining, and some very silly decisions about how to seal up the camshafts which is why it leaks so badly. They made the 40V much cheaper to build, and slighly better at containing its oil, but then burdened it with so much emissions crap that I bet it ended up costing more
Sunday's update:
The PF subframe doesn't have the lower braces that the FL does, but we can fix that while its in bits and sandblasted. Marked out the bolt locations and drilled some holes
Welded some M10 nuts in place
Pretty colours before painting, and nice even weld penetration
Painted. Dealing with this took most of the day which is why I hate doing subframes
I realised something looking at the engine - someone definitely designed this thing to be turbocharged! There is an oil port blanked off on each head which would have been for the oil feed, and a boss in the block on each side for the drain.
The feed
Drain port on the right
and on the left. These would have been drilled and tapped for banjo fittings. I'm not sure whether the ABZ has this as well - I've never looked at one in this much detail.
Aluminium oil cooler pipe
Mann oil filter which comes with all the seals
Oil cooler back on.
ID:	26860   Click image for larger version
ID:	26861   Click image for larger version
ID:	26862   Click image for larger version
ID:	26863   Click image for larger version
ID:	26864   Click image for larger version
ID:	26865   Click image for larger version
ID:	26866   Click image for larger version
ID:	26867   Click image for larger version
ID:	26868   Click image for larger version
