Old 1st September 2021, 02:54 PM
Turns out the eprom is a surface-mount 27C1024 so I'm not messing with that - I don't have the gear to remove and re-fit it. Bottom right with the sticker on it.
However, having realised I have almost all the parts needed to do the manual swap I put the original manual ECU number in to ebay for a laugh. One available, in Lithuania, for £100 delivered! Er, yoink!
So, if anyone reading the thread is pondering buying this when its done, you've got two weeks to get in touch and let me know whether you want it manual or automatic
In the meantime, I'll be working out how to make my clutch pedal solution work with the PF's accelerator cable...
Old 1st September 2021, 03:05 PM
Ronin Ronin is offline
I do have the tools to remove it and put it back on and I'll be passing by your workshop next week, you are welcome to borrow them or I can do it for you.
If the board has conformal coating on it it will be a pain to do it.
Old 1st September 2021, 03:07 PM
Snaggle57 Snaggle57 is offline
I’ll buy the ecu if you want to convert mine instead
97 S8
97 A4 2.8Q
05 A6 1.9tdi
89 VW Caddy GTI
Old 1st September 2021, 03:50 PM
I may take you up on that if the ebay ECU doesn't work out, although I won't know that by next week. Its been a long time since I did surface mount work. There's no coating on the board
If Ronin is on board with socketing the ECUs then that's certainly one less hurdle. There's still a very limited amount of manual parts though. If I convert this one I'm almost certainly sacrificing the swap in my grey FL, or at least not being able to do it with factory parts.
Old 1st September 2021, 05:09 PM
Maybe I should not have mentioned a manual gearbox.....
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 1st September 2021, 05:37 PM
I wonder what the asking price will be for a perfect s8 like this...
Old 1st September 2021, 09:02 PM
pete-p's Avatar
pete-p pete-p is offline
That's interesting, I sold my spare headlight washer pressure cylinder to someone in Lithuania, it took weeks to get through customs so be prepared to wait!
Cars...
Old 3rd September 2021, 09:10 PM
Five original Avus 1 wheels with centre caps These were actually the reason I bought the car since they are so rare. Even if the car turned out to be a lemon, it was worth buying just for the wheels. These are in for refurb while its on the lift
Like this set on ebay, though centres are different?
https://www.ebay.co.uk/itm/Audi-S8-D...-127635-2958-0
Paul
Gosport UK
Old 3rd September 2021, 09:15 PM
HPsauce HPsauce is online now
No, those are the facelift versions on eBay. Very different if you are familiar with them.
The originals are the ones to have, the centres are rare as rocking-horse poo!
Old 9th September 2021, 08:41 PM
Fuel line clips all replaced
The fuel line from the filter was very crusty so I replaced the banjo fitting and hose, along with the filter of course.
New TRW brake hoses
This rear brake line is very crusty so will also be replaced
Brand new rack-side PS pressure hose, plus refurbished front pressure hose and return.
Fitted
Nice of Audi to put marks on pipes so they can be lined up
PS hoses fitted with a new clip, and the replacement brake line also in place.
Manual ecu on the left, auto on the right...
ID:	27170   Click image for larger version
ID:	27171   Click image for larger version
ID:	27172   Click image for larger version
ID:	27173   Click image for larger version
ID:	27174   Click image for larger version
ID:	27175   Click image for larger version
ID:	27176   Click image for larger version
ID:	27177   Click image for larger version
ID:	27178   Click image for larger version
