Old 1st September 2014, 07:27 PM
Audi do Audi do is offline
I also did this job with a trolley jack. Also found it annoying I could not fit a stand under the car when jacked up.
Thread hijack alert.
Has anyone any advice if it's possible to get stands in and where?
I jacked the car over the weekend but had to have it half in/out of workshop so I could position the jacking pad over the dip at the doorway. I simply lifted it using the trolley jack, is there a good spot to put axle stands (be kind I've just bought the A8) has anyone managed to get a low profile trolley jack that will go low enough to slide in? My current one is milimetres away from being usable, I'm considering simply carressing it with the angle grinder (the trolley jack not the car )
Old 2nd September 2014, 12:50 AM
sarg sarg is offline
I've always found the easiest method with any lowish car is to drive it up on to a couple of planks of wood, that usually lifts it enough to get a trolley jack underneath
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 2nd September 2014, 07:43 AM
As I think I've mentioned in another thread, I use the standard jack to lift the car an inch or two then slide the trolley under. They use different locations so it's no problem.
Old 2nd September 2014, 10:37 AM
Originally Posted by jools_s8 View Post
Thanks for the reply. I could not get enough of the stand on the sill without risking damage or worse the car coming off the jack.
Don't use the sill to jack off as it'll just fold in. I've always put the boot jack at the rear jacking point wound it up a touch so you can get you trolley jack under the front jacking point, pump your jack up so you can fit the axlestand under the subframe.
Where do you use for the trolley jack just out of interest?
Old 2nd September 2014, 10:57 AM
Where? As rarely as possible and only when I can't quickly get a professional to do the job.
If you mean where on the car, there are pads for lifts etc. as specified in the drivers manual, fairly close to the OEM jacking points.
Old 2nd September 2014, 11:36 AM
The only use I have found for the OEM jack is to slightly raise the car so that a proper (e.g. trolley) jack can be slid underneath to then lift using the pads.
So there are 8 lift points on FL? As far as i'm aware there are only 4 on the PF and the standard jack fits into these.
No i must have meant where on the planet, why would you assume i meant where on the car? Just because the whole thread is about where to jack and support an 8?
Old 2nd September 2014, 12:01 PM
I thought PF and FL were the same underneath as the body shell wasn't changed. But my PF is long gone.
My FL manual clearly illustrates four ridge-like jacking points (A) for the vehicle jack and another (larger, square) four (B) for workshop lifting platforms.
Old 2nd September 2014, 07:03 PM
The best solutions are always the easiest, cheers for that Sarg. I am better prepared for next time.
Old 3rd September 2014, 04:04 PM
The cheapo Machine mart one will fit under a S8, the cheapest one (red), I think it was something like £25.
Sarg's idea is best, drive onto planks or similar.
