Old 21st June 2018, 07:56 PM
Regulus Regulus is offline
Thank you for the information
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 21st June 2018, 08:03 PM
Old 22nd June 2018, 05:04 AM
27litres's Avatar
27litres 27litres is offline
Over here it's simply
"Statutory" or "Non-statutory" Write Offs.
Statutory write-offs are where there is structural damage which makes the car unsafe to be put back on the road.
Non-Statutory write-offs (the vast majority) are when repairs become uneconomical in relation to the value of the car.
So repairable write offs.
These can be put back on the road if so desired, but must pass a VicRoads inspection at their facilities.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 25th August 2018, 12:43 PM
Back on with this one after getting back from Germany, since it has a new home to go to. In order to keep the sale price sensible (and avoid delays ordering parts), some recycled parts are being used in this one where appropriate.
One of the tie rod end boots was split so tried taking the old one off but it was totally seized in to the tie rod
Fine. Sawzall then
The tie rod was pretty nasty so no great loss
Everything removed and cleaned up
Replacement tie rod and greased up the rack
This clip is not fun to do with the rack in the car!
Back together
ID:	19970   Click image for larger version
ID:	19971   Click image for larger version
ID:	19972   Click image for larger version
ID:	19973   Click image for larger version
ID:	19974   Click image for larger version
ID:	19975   Click image for larger version
ID:	19976   Click image for larger version
Old 25th August 2018, 12:52 PM
Started putting the interior back together. It had the remnants of an old Nokia car kit, so pulled the tunnel sides to remove all that.
More random wires
Wait, whats that doing just dangling?
The wires for the shifter postion light have become detatched 'somehow'
If there's one thing I'm not short of, its auto shifters so that's easy enough to fix.
Noticed a loose penny sitting down by the shifter! Poked it down under the sound deadening and then retrieved it from the footwell
This is the first D2 I've had in the workshop which has an intact starter junction box. Leave that alone for a change
ID:	19978   Click image for larger version
ID:	19979   Click image for larger version
ID:	19980   Click image for larger version
ID:	19981   Click image for larger version
ID:	19982   Click image for larger version
ID:	19983   Click image for larger version
Old 25th August 2018, 01:09 PM
I noticed the AC compressor wasn't kicking in so checked the gas - none present! So, took it to get re-gassed, but the compressor still wouldn't kick in. Poked around for a bit and discovered the compressor was seized Took all the gas out again, and went back to the workshop to swap it over.
Its a piece of cake on the V8 - three bolts and it drops out of the bottom. Not so on the V6 - the oil cooler is in the way
Oil filter off and AC hoses removed. The oil cooler coolant hose also has to come off so the coolant needs draining too
Ideally the cooler would come off too, but since its not leaking and I don't have a spare o-ring its staying put. That makes this bolt rather tricky to get to
The compressor just fits out between the cooler and chassis leg
Cleaned up the space it came out of
All back together ready for regassing a second time
Since I had the coolant out its a convenient point to swap out some compromised cooling system components. The expansion tank was broken at the top vent pipe
The T-piece was also cracked and leaking
As was one of the heater bleed valves
The vent hose is attached right down here and was also leaking
Turns out the clip had been mashed up so the hose just pulled off!
This was quite a mess
Conveniently I have a V6 donor car (not Big Red!) which relinquished a perfect set of replacement parts
I also replaced the radiator vent hard-line with the very last one ever, as these became NLA after I ordered this one This might be something else I need to re-engineer in a different material.
ID:	19985   Click image for larger version
ID:	19986   Click image for larger version
ID:	19988   Click image for larger version
ID:	19989   Click image for larger version
ID:	19990   Click image for larger version
ID:	19991   Click image for larger version
ID:	19992   Click image for larger version
ID:	19993   Click image for larger version
ID:	19994   Click image for larger version
ID:	19996   Click image for larger version
ID:	19997   Click image for larger version
Old 25th August 2018, 03:28 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Not sure how I missed this initially
Always a great read MJ glad an 03 is being saved!
2016 S5 Coupe Black Edition - Ibis White
Old 25th August 2018, 04:54 PM
Reporting in from Edinburgh.
I only have to look at my tool box and my nails split and break.
MJ still has perfect nail varnish!!!!
Old 25th August 2018, 05:08 PM
Norretal's Avatar
Norretal Norretal is offline
Ha...I noticed that Ray but decided not to comment
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should
Audi TT - 2015 - Ultra
Old 25th August 2018, 06:20 PM
Not so much today!
Vacuum coolant tool
