Old 21st August 2021, 08:53 PM
Looks amazing! I wish I had your patience to clean mine, its a bit grimy inside.
What do you use for cleaning grease and grime off the painted bits?
Would brake cleaner start attacking the paint?
Old 21st August 2021, 09:29 PM
Chlorinated brake cleaner probably would. I use a naptha-based brake & clutch cleaner from TPS which is very mild but which cuts through oil and grease very well indeed, although ironically it doesn't dissolve brake fluid Its much easier on PF and FL1 though as they are lacquered in the engine bay and so quite robust. The FL2s aren't lacquered so you have to be very careful not to dissolve the paint! On those I use Gtechniq W7 tar remover as that is quite benign and remarkably powerful. I also have a product called 'Dirt Juice' bike cleaner from my neighbours which is also quite a mild solvent but in an aerosol so it has dirt-blasting power if needed.
Once the oil is gone I use Gtechniq W5 APC most of the time, in varying concentration depending on the level of grime. In this case, being the worst I've encountered so far, the W5 was mildly supercharged with 10% Autosmart G101 which is an extremely powerful alkaline APC - basically a trade version of the Elbow Grease product discussed in other threads. I'd be disinclined to put G101 anywhere near an FL2 engine bay though. Beware toluene-based tar remover as well as that also dissolves the unlacquered paint.
Once it's all clean-ish with no more grit or chunks I'll use a waterless wash or quick detailer to tidy up any smudges, and then a sealant to finish off.
Old 22nd August 2021, 10:40 AM
I am going to stick to the ones you recommended. The Halfords brake cleaner I have seems to attack the paint/lacquer. I think mine is FL1? Autumn 2001 build date.
Will the naptha brake cleaner from TPS also work on the engine block?
I'll have a lot of cleaning to do there.
Old 22nd August 2021, 11:11 AM
Yours is FL2 so mild cleaners only in the engine bay. Yes, I also use the TPS brake cleaner on the mechanical bits like engine and gearbox. I buy it in 5 litre cans and use it in a spray bottle as it goes much further for the same money than the 400ml aerosol which is gone in seconds.
Old 22nd August 2021, 01:52 PM
Thanks Mikki! Great advice as always!
I’ll be very careful in that case, that explains why the Halfords one attacked the paint so easily.
Old 23rd August 2021, 08:18 PM
As usual the fuel line clamps have rusted away so these will be replaced
Original fuel filter?
The fuel line rubbers will be soaked overnight in Bilt Hamber Korrosol to remove the embedded rust
Purple gloop
I put something back in!
The connector for the servotronic solenoid is easily accessible, despite Audi's assertion that they used the ridiculously fragile trailing cable to make it possible to install the rack.
Connector harness attached
I run the cable over the top of the rack out of the way, rather than underneath like the factory did where it could get cooked by the exhaust
This plastic nut used to go on the stud which is now replaced by an M6 rivnut, so I screwed some M6 threaded bar in to it to make a hybrid bolt
Works perfectly
ID:	27046   Click image for larger version
ID:	27047   Click image for larger version
ID:	27048   Click image for larger version
ID:	27049   Click image for larger version
ID:	27050   Click image for larger version
ID:	27051   Click image for larger version
ID:	27052   Click image for larger version
ID:	27053   Click image for larger version
ID:	27054   Click image for larger version
Old 24th August 2021, 09:19 PM
The aux belt tensioner in the PF is part of the timing belt cover. Its a complicated affair which runs on a pair of needle roller bearings which I had to remove to get it powdercoated
Two new bearings, and I made a tool to press them in to place
One of the bearings fitted
The tensioner, complete with massive spring just waiting to go sproing and break something / someone
Tensioner arm
Assembled view from the back.
I managed to put it together without scratching anything or the spring going sproing. I also fitted a new fan pulley bearing. I need this to finish the timing belt reassembly as the crank pulley locking tool fits in to the slot at the bottom of the cover
Fuel line rubber doodads now free of rust
They'll soak in rubber care solution overnight
ID:	27068   Click image for larger version
ID:	27069   Click image for larger version
ID:	27070   Click image for larger version
ID:	27071   Click image for larger version
ID:	27072   Click image for larger version
ID:	27073   Click image for larger version
ID:	27074   Click image for larger version
ID:	27075   Click image for larger version
Old 25th August 2021, 07:15 PM
I put the inside of the inlet manifold back in and noted that this arrangement of vacuum pipes is very silly indeed, especially since it just flaps about.
Much better I've also tucked the vacuum reservoir hose under the inlet manifold and out the back, instead of it dangling over the top of the PS pump. More on that later.
I finished off the timing belt setup and got the tensioners correct and the locking tools removed. Next job is to visit the local tractor workshop and see if they have a torque wrench that goes to 450Nm so I can do the crank pulley bolt
I couldn't put the old rotten rubber seals on the beautifully powdercoated covers, so even though the price of new seals is £ it just had to be done
Covers back on, and I'm pretty pleased with how smart they look
Manky rotten rubber here would just have let the whole thing down
ID:	27085   Click image for larger version
ID:	27086   Click image for larger version
ID:	27087   Click image for larger version
ID:	27088   Click image for larger version
ID:	27089   Click image for larger version
ID:	27090   Click image for larger version
Old 25th August 2021, 08:46 PM
pete-p's Avatar
pete-p pete-p is offline
Those covers are just lovely so much nicer than the plastic ones on the 40v.
Cars...
Old 25th August 2021, 09:43 PM
Audifan Audifan is offline
I totally agree.
Just wondering, will the 32v timing belt covers fit on the 40v engines?
