Old 22nd June 2018, 03:02 PM
homer simpson's Avatar
Another little mod I would like to do - fan spray washer jets.
Now reading through the thread I have concluded that my 2008 S8 will need a spacer to fit the SKODA heated fan washer jets. It already has the triple jets as standard.
Old 22nd June 2018, 03:28 PM
Not quite. The FL D3 doesn't require the spacer, but the PF D3 does. See the comment by tc4332 (Ray) regarding the reasons.
I know that the ones I bought off AliExpress and fitted to my '08 S8 were fine. I did buy another set to fit the '04 A8, but haven't got around to fitting them. In theory, they should be loose and require the spacers, which I also bought. If I can both parts, I'll try fitting them today and confirm what Ray said.
Old 22nd June 2018, 05:14 PM
Thanks. I read Ray's posts and confused myself! It's clear now, the PF requires them if going from a 2-jet to a triple jet (or fan) but the facelifts don't require them. Time to order a set from Aliexpress as TPS want nearly £25+vat for one.
Old 22nd June 2018, 05:38 PM
My pleasure to be of assistance.
Old 22nd June 2018, 06:31 PM
And just to confirm what I said was correct, I've managed to find the new jets and shims and fitted them to the '04 D3, and they work fine. The fiddly bit was fitting the shims.
Old 3rd July 2018, 08:23 PM
Mine arrived today, installed, adjusted and working perfectly
Old 8th July 2018, 01:27 PM
For those fitting these to a PF D3 that require the addition of shims, I came across this image that might help with how the shims are fitted in relation to everything else.
Old 14th November 2019, 02:57 PM
Norretal's Avatar
Norretal Norretal is offline
This thread has all of the information you need about the D3 fan jet upgrade dangerdred
Audi TT - 2015 - Ultra
