D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Thanks Neil
Audi S8 2002, Black (even the chrome bits) Audi RS6 Avant 2008, Daytona Grey Maserati Granturismo 2008, Metallic Nero Carbonio Audi S8 2015, Daytona Grey |
Happy Birthday Brian
Re the mystery brown stuff. Have you considered exorcism
cheers Nick
might be my next move
That looks like dirty water from inside a compressor.
Compressors draw in moisture with the air & theres usually a bleed valve which is meant to be drained. Tyre valves can (and quite often) actually leak ever so slightly from the valve core (easily sorted by using a valve core tool. That's the main reason for having a slow puncture. Try tightening the valve cores & putting caps on |
Where did the tyres come from by the way?
bought them on-line David, fitted at local fitter I have used before
Just wondered whether they had got some substance inside them when stored prior to fitting? That could account for 3 of them and not the other having the staining if one was not stored with the others ??
its possible, they were delivered in two lots, just been cleaning them and its not compressor oil either. I think the only way to get to the bottom of it is to get the tyres removed and take a look inside. I am now wondering if the wheels are of a "double skin" type construction? and maybe something has managed to find its way between them? really clutching at straws now TBH
well solved at last This stuff had damaged the paint on the wheels so took them in for a refurb. Turns out my "double skin" theory was correct, top of the wheels including where the valve sits is double skin and this stuff had got between the two layers, refurb seems to have got rid of it thank goodness
