Old 3rd January 2013, 07:07 AM
OK so plastic front and back but very different types of plastic surely? I just don't want his Lairdship to attack the rear lenses in the same way if they cant take it, just have a feeling its very different plastic thats all
I have a couple of spare rear lenses that I'll experiment on first.
Old 3rd January 2013, 08:51 AM
Iyole Iyole is offline
What's the rationale for using PlastX and ScratchX in different places? Looks like I may need to order another product!
Apology .... Typo ... only PlastX used .... ScratchX is for paintwork.
2002 S8 D2 F/L
Old 3rd January 2013, 09:04 AM
With the outer Lens the indicator housing is part of the Lens and getting access
to the inner face of this portion of the Lens posed a challenge.
I was not keen to go the heat- gun route to remove the housing from the lens
due to previous experience with not being able to get a 100% seal on re-fitting
and constant water ingress problems.
So once again I raided the SO's Kitchen and sourced a flexible Spatula .... worked perfectly
with a Micro-fibre cloth wrapped around it and secured with Duct-Tape ...
All squeeky clean and ready for assembly...
Assembled and back in-situ ...... stoked with the result....
Had visions of going for sobriety courses if I was forced to purchase a replacement at R 21 K
as the Frostie Fund would have had to liquidated....
2002 S8 D2 F/L
Old 3rd January 2013, 09:39 AM
I'm pretty sure the PF ones (like wot eye ave) are glass.
(indicators are definitely plastic though)
PF is glass because they weren't built cheap like the later cars Indicator is a separate part and slots onto the main headlight.
Was just thinking has anyone rang Audi or TPS to ask how much a plastic lens is? Only reason i ask is i bought glass lenses for my PF and they were just over £25 each. Just wondering if they'll be cheaper being plastic.
Old 3rd January 2013, 10:00 AM
I would hope that the move to Plastic was due to weight saving and not cost saving
I doubt that a plastic lens would be available for the PF nor a Glass lens for the
FL ..... Due to the Indicator lens variation ....
2002 S8 D2 F/L
Old 3rd January 2013, 10:19 AM
You reckon it was weight saving decision? The glass ones are not that heavy, it might have been done for safety over cost as i have been through 2 lenses on the front through smashing so i suppose if i drove into someone with a broken lens i could have cut them.
I wasn't suggesting a glass lens is available for a FL car just that manufacturing a glass lens must be more expensive than a plastic one.
Was just thinking if this manufacturing cost saving was passed onto the customer then it might be worth just buying 2 replacement lenses.
Just thinking 25 for real glass lenses and what 15 for plastic? Yeah right Dez
Old 3rd January 2013, 10:27 AM
I think it's probably for ease/cost of manufacturing.
Plastics technology has evolved a lot in recent years with (in my opinion) some quite bizarre and complex lights as a result.
Just because you can do it doesn't mean you should.....
Old 3rd January 2013, 12:30 PM
A Google search revealed ....
The use of plastic in headlamp applications enables automakers to reduce weight without sacrificing optical performance while increasing resistance to breakage.
Plastic offers the advantage of being an inherently light material that can be easily made in thin sections and stepped shapes, reducing weight and the possibility of breakage “without sacrificing optical performance.
Plastic’s versatility allows auto headlights to incorporate designs that can increase highway safety, such as high-tech focusing designs in the lenses.
Polycarbonate, sometimes used as a bullet-resistant glazing on other applications, has about 200 times the impact strength of glass. This strong, stiff, transparent thermoplastic can maintain rigidity up to 140° C (284° F) and toughness at -20° C (-4° F).
2002 S8 D2 F/L
Old 18th January 2013, 08:22 AM
A look at Elsaweb showed that there is a kit for repairing the headlight unit clips if they break during removal to save replacing the whole unit. Obviously a known problem.
See http://elsaweb.spaghetticoder.org/do...-EA/20839180/2
Old 3rd January 2015, 11:30 AM
Can we add this thread to the repair sticky? Came across it looking for previous experience of stripping headlights and thought it's really useful
