Key switch stuck
Afternoon all,
Finally got the project home and parked on the driveway this afternoon. Decided to connect up some power with a slave battery and see what is/isnt working. To be fair to it everything sprung in to life ok. Windows/sunroof/mirrors etc all doing as they should. Even all the interior/exterior lights are working fine. Only small snag....switched everything off but the ignition key wont come out of the lock....am i being thick or should it just come out? It did ok when the battery was disconnected
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
Gear selector needs to be in P
Done that, now suspect it may be an electrical gremlin to do with the selector/ignition release solenoid
There was a recall on this solenoid, as mine got done. Mine's is a '01, so yours may have been on the list but never done.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
Transmission is going in to park OK as the dash shows up 'P'
I suspect the solenoid has got stuck as the key would turn all the way to off before I connected the battery. It's now stuck at the first position. Steer column covers will be coming off this week and a liberal application of WD40 should cure it.... if not a little percussive maintenance
There should be a small pin whole in ingition, ring around key slot. Use a needle to press and key pops out
Now that I didnt know!!
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
Ooooohhhh, gotta try that before I get the screwdriver out
Problem solved
Got an hour to myself this evening, pulled the steering column apart. Turns out there is a cable running from the gear selector to the ignition switch.
When you press the button on the side of the shift lever the cable retracts locking the key into the ignition barrel. Turns out the liberal application of wd40 was needed on the cable as it was simply not returning properly. Job done, key now out! ......now just need to put the engine back together
