Old 28th August 2010, 07:56 PM
woodshed woodshed is offline
Default How do you get the bolt out from the suspension guide link?
Hi guys, I am trying to replace the guide link on my front suspension, lower-rear.
I have got a tech manual that tells me to undo the three bolts that hold the subframe and that should lower it enough to get the bolt out. Guess what - no lowering!!!
I have seen someone suggest cuttin the bolt - but how do you get the new one in without using a large hammer?
Any help would be appreciated.
Martin
Martin Wood
Rescue Helicopter Pilot
Work in Ireland - Home in Devon
Old 28th August 2010, 08:33 PM
If you cut the old bolt out by grinding off the bolt head you will need a long nosed pair of pliers and ease the thing out into the subframe.
I always insert new bolts in by putting them into the subframe head first towards the front then threading them into the hole for the link using long nosed pliers.
As for lowering the subframe you need to support it with a jack and undo all 4 bolts. Lower the jack (very carefully) take out the bolt then jack it back up.
Old 29th August 2010, 10:20 AM
Default Thanks Conan
Thanks a lot Conan. Worked a treat cutting the bolt then putting the new one in from the other end.
One down one to go!
Martin
Martin Wood
Old 30th August 2010, 05:32 AM
I'm too late but yes same here cut the bolt and put a new one other way around.
