which hub bearing?
Anyone know what kind of front hub bearing would be in a 97 D2 FWD 2.8? It lists either push fit or bolt on for mine which isn't much help! It does offer a chassis break number of >4dx005500 but mine seems to be 4dz..... If i have to crawl under it i will, but frankly i'm just after the easy option
It is almost certainly a press-fit one mate. Only much later ones and Alloy housing ones had the bolt in type. Sorry! Hope I'm wrong as bolt in MUCH easier to fit!!
Are the bolt in housings a direct replacement Ben. Would getting the aluminium bolt in housing reduce the unsprung weight much?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
You can't mix and match steel and ally hubs, which I found out to my cost trying to fit the feckin' RS4 rear calipers. The ally hubs are bolt in bearings (as I've just had new ones fitted today). Oh, and I'm not Ben |
fitting isn't a problem, i've got a big old press for just such occasions, just needed to be sure when ordering.......It's not got any movement in it yet anyway, but there is a faint noise from the osf....i'm hoping its the cheapo radial ditch finder the garage fitted when selling the car! I guess it needed tyres for selling because the fronts are both new (well were when i got it) but the backs are goodyear and a bit older....weirdly the fronts are 2 different brands of hedge missiles! Will recheck for movement at the weekend but yesterday there was nothing at all. Fingers crossed!
