Old 24th August 2016, 03:12 PM
SilverS8 SilverS8 is offline
On sale now for £18,64
Tried to sign up, but only UK it seems like
Two of these would be great in the Boat, when anchored up without landpower available
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 24th August 2016, 03:16 PM
Price dropped in the last few hours!
Matt
Old 17th April 2020, 10:14 AM
There might be another thread more recent/relevant, but I decided to buy a solar "battery maintainer" a couple of weeks ago.
Based on a recommendation on another forum I went for one that "looks" very similar to the Aldi one that started this discussion, but it's branded "AA" (Product code AA4185) and has an OBD connector. No specific output mentioned though there is a larger model advertised as 4.8W; I didn't go for that.
I tested it at over 21V and 0.15A output in good sun (about 3W); same inside the car behind a standard-tint windscreen. It seems to be maintaining the battery at an adequate voltage (I've been monitoring it roughly every other day); I started it today for the first time since purchase and it turned over briskly.
I'm not too worried about the battery running down, other than it doesn't do it any good. Charging it up again and entering radio codes etc. isn't a big issue for a D2 fortunately being rather old-school in that regard. Our much newer Volvo on the other hand with twin batteries, stop-start etc. would probably be a right royal PITA if it went flat.
Old 22nd April 2020, 09:41 AM
In the end I bought the larger 4.8W one as well and it arrived today.
Tested at about double the amps of the smaller one so I've fitted it to the S8.
The smaller one is now on the Volvo, though that should get occasional use.
Old 22nd April 2020, 11:42 AM
Johnmed's Avatar
Johnmed Johnmed is offline
I tried the Aldi one, it’s of no use.
Do you have a link to the 4.8W panel HP?
2007 Mini Cooper S R56
Old 22nd April 2020, 12:36 PM
I just searched for AA 4.8W solar charger on eBay and chose what looked to be the best price/feedback. There weren't many...
This is the one I bought: https://www.ebay.co.uk/itm/AA-4-8W-X...y/184168474667
Old 22nd April 2020, 08:38 PM
I've been monitoring the battery voltage with the smaller "charger" panel attached and it was fairly stable. The battery, despite being not that old isn't in great condition due to lots of really short journeys over last winter; it dropped low enough to not even start a couple of times and even lost the radio code once relatively recently.
However with the new 4.8W panel attached today for about 10 sunny hours the battery voltage at the end of the day was higher than I've seen it for some time (except immediately after having a drive) so I'm feeling positive.
I can't recall the exact battery capacity, but it will presumably be of the order of 100Ah. If the solar panel can deliver even half of its advertised rate that's about 0.2A, 2Ah over the day. Not masses, but way more than enough to cover the remote locking receiver and anything else running when locked. Maybe even enough to freshen the battery up a bit?
Old 30th April 2020, 02:40 PM
johnny_quattro's Avatar
Default Same or different?
Thanks for posting about the 4.8W panel, which interested me as mine is a 2.4W panel with an optional OBD-II connector. The link posted only seemed to show a panel that mentioned crocodile clips but no mention of the OBD-II connector.
I did some hunting around and found this one, which is about £8 cheaper and clearly states that it has the OBD-II connector:
https://www.ebay.co.uk/itm/AA-4-8W-1....c100010.m2109
Would you be able to confirm that this one is the same as your one?
Many thanks in advance, Mr Sauce.
Cheers,
Johnny G
Old 30th April 2020, 03:50 PM
That does indeed look the same, and is cheaper.
Old 2nd May 2020, 05:06 PM
Cheers for the confirmation. Just a quick note - after having left my car for 3 1/2 weeks, it started on the button although a quick multimeter reading beforehand showed 11.8V. As a result of the above, I will be looking to upgrade from my lowly 2.4W panel to the lofty heights of a 4.8W panel.
Stay safe everyone and keep washing those hands. I cannot wait to wash my car again.
